Recently I have noticed goods and services in Japan have increased.
for example I went to my local family convenience store the other day for some coke and they wanted 400円 for a 1.5lt bottle of coke zero
then Today I was shocked by the price of the nismo package for the r35
Check out this f**king watermelon ! :blink:
https://www.sau.com.au/forums/topic/233910-fruit-just-not-what-it-used-to-be/
I dont know what they put in the fruit over there:post-32255-1220019718_thumb.jpg
When i was over there last i was doing a bit of shopping and had to snap this. These apples were friggn huge!
Two old ladies next to me thought i was nuts,taking photos of an apple with a lighter next to it :blink:
Doesn't anyone watch the news anymore? NHK have been reporting on tax increases on groceries etc since at least June or so.
All to do with the aging population you see :banana:
damn , did no one see the price or the fact the watermelon was shaped as a heart. its a 200 dollars watermelon.
as a side note
a japanese man yelled at me in a supermarket today telling me to go back to my country. all because i moved his wet umbrella off the soup rack so i could see which soup I wanted to buy for dinner.
im gonna look for him then kick him in the teeth, then call him a racist f...k...in c..t again!
as a side note
There's a bunch of 2 and 3 hundred dollar rockmelons for sale here in Tokyo. And they're not even shaped differently to normal ones. I thought it was just one of those little quirks that people always go on about; Used panty vending machines, 8 dollar cups of coffee et al...
The yelling Japanese man was probably just angry at you because NHK ran another story about how the horrible foreign workers in this country are responsible for everything from rising crime rates to the recent spate of flash flooding.
lol, that would make an excellent Valentines day gift if you think about it...
Romantic...well, that depends.
Memorable...farkin oath.
Oh, yeah while im at it...
All you expats should be going to COSTCO for fruit and veg...holy cow..
Picked up 1.5 kilos of proper green grapes ( not the ones you have to bloody peel - hate them ) and a kilo of black cherries for 2000 yen.
Now thats value in anyones book.
m3gtr, costco is a very excellent place. i bought a 6.3 kilo the sphincter of the universe there last christmas.
as not many people were impressed with my heart shaped watermelon . and seen as how this thread has gone some what of track ....(not sure if it had any tracks to begin with)
I bring you more watermelon themed pics
The first
Square Japanese watermelons
The Second
Japanese watermelon art
The Third
Strange faced Watermelons
this thread now has no purpose:(
The first
The Second
It's worth every cent. I'm tired of fumbling with round fruit. D'oh (drops watermelon as it expands to normal round shape).
You're actually getting 27.9% volume of extra value with those square watermelons. not to mention the savings from packing space, ease of stacking, don't roll around...
  • 1 month later...
There are places to buy stuff at reasonable prices still. You have to look around. But still then again when compared with prices back home it's really painful.
a pack of 10 eggs at one of the shops I go to is only 99 Yen (for a pack!).
Then you got those 4L plastic bottles of whiskey or sake for like 3000 Yen. Now where can you find alcohol in Australia for that price, Let alone a 4L bottle! (would you like a straw with that?)
Cigarette packs at 300yen
So there are some things that are cheaper
Just avoid the watermelons!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
