Thanks pete but anyone would help. Sorry to highjack thread but
I have to say Pete, I have utter most respect for the effort you are putting in to help Adrian, Damo and Everyone involved. Helps bring some faith back into society when people go out of their way and at their cost to help others out, especially to this extent. Thankyou.
I'm gonna hijack too.....thanks right back at ya Ryan :D
https://www.sau.com.au/forums/topic/234094-defected/page/7/#findComment-4108317
  • Replies 129
Posted Images
  • 3 weeks later...
took my car into regency today, had a young guy with a shaved blonde hair check over my car, he was a really nice guy, was joking round with me and everything even payed me out for stalling it while taking it over the pit and complimented me on my shortshift...lol
he couldnt find a single thing wrong with it (i put it back to completly stock as if it just came out the factory), asked me a few questions then did a break test, took my sticker off then joked around with me by saying "i bet u going to put it all back on, so ill see you in 2 weeks...lol"
they arn't all Bastards there!!!!!!!!!!
while on defect i was contemplatig selling my car after coz i was over it all, but the support i have got from everyone who have offered me spare parts and lent me parts and also help to fix it has been overwhelming and i really appreciated it, so now i have i have decided to keep it and make it into a SLEEPER
big thanks goes to Ryan, Guy, Sonya (nos man), Michael and Peter at Aussie Dyno and eveyone that bought my spare parts
Thanks Dan
https://www.sau.com.au/forums/topic/234094-defected/page/7/#findComment-4143696
Thanks Dan
did the bloke at regency's name happen to be Mac??? or did you not find out? if it was, i used to work with him at jeep, he's a larrikin and a champ, would def do his best to get ya through regency first time provided your car is something phat. gemis' commo's, TN magnas = FAIL :P Great news though Dan :P
https://www.sau.com.au/forums/topic/234094-defected/page/7/#findComment-4143732
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
