Hi!
I was offered a nice 3row 52mm alloy radiator for a good price.
And wanted to know if there are any real life benefits vs running a more common 2row.
Anyone running 3row one on their r32s/a31/s13 ? How well does it work with the clutch fan ?
Thanks!
Hi!
Thanks!
Hi Robots,
I actually build alloy radiators for a living, here's my thoughts.
I like big tubes, The wider the tube the more fin contact and the more heat gets pulled out/dissapated I would rather go with 2x27mm tubes over say 3x19mm tubes.
I dont like 3 row cores, All our cores are 2 row 57 thick, Which is 2 tubes at 27mm thick.
Our radiators will NOT work with the standard clutch fan, though, It's just too thick. I think a 42mm would be best for a street driven car that gets a bootfull every now and then.
Thanks,
Scott
Remember that a radiator needs air to flow through it to work properly. The factory shroud and clutch fan is a very effective setup and sucking air through the radiator.
There is a lot of work to ensure good flow of air if the shroud is not used. I would recommend staying with a good quality 40mm radiator which enables you to retain the factory shroud and clutch.
Hi Robots,
Thanks,
Scott
If your radiators dont work with standard fans, then waht do you use that works?
At a guess, thats up to the individual, he just builds the radiator :P
I have heard from a few people that have gone to AM radiators with electric fans that they have had overheating issues. That clutch fan and shroud is dam efficient! Takes forever to get to operating temp when bleeding the system. Ha.
Like was stated, for street driven/occasional track use the thinner core (which fits standard shroud) is good.
The larger core would probably be aimed at higher output engines, in which case they are probably using high quality thermofans and shrouds to suit, (not like some people I know who bought 2 fans from supercheap and cable tied them to his radiator).
Thermofans can work well when they are setup correctly with decent gear. For what it's worth, the EL-AU falcon thermo fan setup is a decent setup which can be sourced relatively cheap both brand new and 2nd hand.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
