Hey Guys,
On any cold start my car won't turn over unless throttled. Feels like it wants to cut out.
It does turn over no problem once warm.
Its got new fuel pump, fuel filter, plugs ands leads and this was happening before these went in also.
Please would anyone have any experience with this sort of problem??
Any help would be really appreciated!
https://www.sau.com.au/forums/topic/234278-help-please/
Hey Guys,
Could be a blown headgasket, water seeps into the cylinders over night, won't turn over in morning, and runs like a dog until all the water is out of the cylinders, opening the throttle helps to get the water out.
https://www.sau.com.au/forums/topic/234278-help-please/#findComment-4105331
Had a somewhat similar problem, got worse and worse, until it wouldnt start at all.
Struggled bad to start when cold, but when it was warmed up it would start.
Turned out to be the CAS. Considering the ECU changes the timing depending on whether it was hot or cold it would easier/harder to start.
Ended up with the car not wanting to start anytime at all, not even jump-started. Changed the CAS and now all works fine :wub:
https://www.sau.com.au/forums/topic/234278-help-please/#findComment-4105913
Ended up with the car not wanting to start anytime at all, not even jump-started. Changed the CAS and now all works fine :)
Thanks for the suggestion!
I'm not sure what "CAS" is?... but is there a way to test whether it is that?
https://www.sau.com.au/forums/topic/234278-help-please/#findComment-4126789
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
