Pics as promised. used my crappy phone camera but will take some better pics later on with a proper camera.
17x8 +17, 225/45 front
17x9 +17 235/45 rear
fronts stick out like 2~ish mm - prob will sit flush with a 215/45 tyre
rear fits perfectly fine - neither needed any guard work however the fronts needed the splash guards removed.
for the rears, if i was to choose new wheels, id go +13~ & for the fronts i'd go +20.
may lower it some more in future to get it sitting a bit better but im happy atm with its fitment.
Edited by dori32
I'm going some Work Emotion XD9s in bronze on my dark blue pearl R34 GTT Coupe, my car sits damn low, you have no hope of getting a coke can around the front or sides, only the back is a abit forgiving. Going to have streched tyres on her.
Front : 18x8, +35 offset
Rear : 18x9, +38 offset
I hope that it turns out okay and sits nicely close to the gaurds.
wouldnt need to stretch the tyres with the widths/offsets your getting for the 34.
for that width and offset 225/255s will be fine to fill up the guards.
if you want the a more aggressive look i'd go. 18x9 +20 215/40 and 18x10 +17 235/40.(or even 18x9+20 all round)
these rims from driftgarage are fken awesome!!!!!!!
for $1080 17" with good size & offsets, cannnot go wrong!!!
this is the new driftkteks atm.
everyone dick & harry is gonnna have them.
www.driftgarage.com.au
Dori,
I just went to their site and checked out the stock.
You were right !!!!!!!!!! Those Project D rims are absolutely awesome.
The price is also pretty bloody good. (if I had any money)
Many thanks for the web site link.
Regards
Jim (TR34GT)
UPDATE: found out my front tyres are 225/50 and i think thats why its scrubbing still!!!!
Hey Dori,
The R34 GTT has a standard 17"x 7.5 + 35 offset Nissan rim that is fitted with 225 x 45 ZR 17 tyres.
The link to the Aaron Bohnen tyre selection guide is listed below. (if you have Microsoft Excel)
If you type in the standard Nissan 17" profile mentioned, in the left hand column, you will be able to see the tyres which will match your car the best in various widths and diameters. It also gives you the information of speed differences due to the wheel diameter differences.
http://www.superjamie.net/garage/tire.xls
The tyre rating symbols for various makes are also as follows:
Tire Speed Rating Symbols:
S - 180km/h or 112mph
T - 190km/h or 118mph
U - 200km/h or 125mph
H - 210km/h or 130mph
V - 240km/h or 149mph
W(ZR) - 270km/h or 168mph
Y(ZR) - 300km/h or 186mph
ZRAbove - 300km/h or 186mph
Yep, the 225 x 50 tyre may cause a few issues in the scrubbing department, and you are also travelling faster than your speedo would indicate. ie........you would be travelling at 103.5 km/hour when you speedo is reading 100 km/hour.
If you save a copy of the guide, it will let you look at all sorts of combinations.
You may also like to check out the past issue of High Perfromance Imports which addressed the maximum diameter and widths that would fit under normal R32, R33 and R34 guards. Apparently, the R33 had the best factory widths for 18 x 8.5 and 18 x 9.5 fitments.
Safe motoring.
Regards
TR34GT (Jim)
Edited by TR34GT-000
Why would you bother getting such horrible offsets when buying new?
Don't be weak, go 18x9 +20 front and 18x10 +18 rear. It'll fit fine with stretched tyres and a bit of guard love...
What about Just Jap for a set of R34 GTR second hand rims? Awesome!
I still like those freekin Lenso rims that Dori found. LOL
For mine, it'll be 17" x 8 front and 17" x 9 rear with some wide 235mm and 255mm Marangoni tyres respectively.
(dreams of more money)
For R34,id stick to 18, 17" dont fill the guards quite well but im not saying 17s dont look good tho.
youd prob have to get bigger sizes for the rear, prob x10 lol
and front & rear with low offsets to fill the fat guards.. rear would be +12, fronts around +20ish
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
