hey ppl.. i gotta r34 n last time i drove it a ''A/T'' light came on in the dash.. i checked the oil, engine etc etc n all was good.. but the light still comes up..
does any1 know wat it meanS!?? al i cud think of was auto transmission :P
THANKS
Edited by lankanboiiR34
https://www.sau.com.au/forums/topic/234610-problem-help-d/
Hey mate.
Most of us driving the GTT Tiptronic have a problem with the AT light at one time or another.
Consensus is that this can be induced (make it happen) by long downhill backing off, or fast cornering accelleration with slip.
The back-pressure induces this condition to Solenoid B, when that solenoid has a lower than normal or failing resistance level.
Next time it happens, take note of what gear the car is locked in.
If it's locked in 3rd gear, it's the AT shift solenoids, specifically solenoid B.
Attached are the diagnostic faults for the R34 tiptronic transmission from the workshop manual.
Hope you manage to rectify this issue.
Regards
Jim (TR34GT-000)
R34WorkshopManual_AT_Faults.pdf
https://www.sau.com.au/forums/topic/234610-problem-help-d/#findComment-4138163
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
