Guys of ive got many parts for a R33 S1 that i need to sell. From panels, suspension, fittings and interior
Here are some:
  1. Passenger Door $120
  2. driver and passenger window regulators $80 each
  3. S1 boot lid with spoiler $120
  4. Elec glass sun-roof $260
  5. Race/bucket seats $350 both
  6. Door trims $40 each
  7. Bonnet $130
  8. Rear lights $50 each
  9. Rear S1 Bar $55
  10. Side mirrors $50 each
  11. GTS front and rear suspension.
Have much more, so if your in need of anything post here or shoot me a PM. Im located in south west Sydney.
Will try to update the post with more parts and pics.
https://www.sau.com.au/forums/topic/235040-heaps-of-r33-parts-and-accessories/
  • Replies 41
Its gunmetal Grey in colour. As for condition it has a few surface scratches. Its of a GTS, but i believe there isnt any difference between the rear bars of each model S1. (GTS & GTS-T)
Can supply pics upon request. Been trying to edit my original post but keep failing, so if anyone can help and explain how i can do it so i can add pics and further details and items, then that will be greatly appreciated.
Dont think you can edit a post 2hrs after you posted it, if you get what that means, got clear indicators or the inside door handle (RHS)?
Edited by R34Maniac
Ive seen people edit the original post when they sell some items, for example they will list it as SOLD or put a line through it. The indicators i have are orange. AS for the handles are refering to the ones within the door trim?
Hi,
I'm in the market for the following for an ECR33 GTSt:
- Headlights (clear not misted either right hand or pair depending on condition)
- Taillight (Right-hand side, Gunmetal Grey would be preferrable)
- Boot Lip Spoiler (any colour but Gunmetal Grey would be wicked)
I am based in Melbourne but can organise courier to pickup and deliver to me.
Cheers!
Mark
Have right hand side rear taillight in gunmetal Grey. $70
Also have the rear boot spoiler in gunmetal Grey. $100.
The two headlights are no good. The bracket that the grill clips on to are broken.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
