thinking about a bit of track action, but also concerned about distance driving in the warmer months.
my current relocater has a thermostat in it.... have noticed on a couple long trips and also after some sprirted driving the temp has climbed north of 90 degrees.
normal city driving, and short squirts in the hills, it stays on 80 degrees
def keen to have a thermostat in new setup
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4116689
i can prob mix and match fittings to plumb up to the B&M oil coolers and thermostats i sell.
pm me if you wish to discus
PM sent :)
I have a cheap-ass Just Jap one in my 34 and it does the job just nicely. Was under $300 from memory.
nice.. that is about as much as i want to spend rly
one question how much oil would i expect to use for an oil change with the cooler in ?
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4116937
I use just under 6 litres with the cooler.
I make sure I jack up the passenger side of the car nice and high to drain most of the oil out of the cooler on an oil change too. Then I unplug the cas and turn over the engine for 30 seconds before starting the car to prime everything up and refill the oil cooler. Works a treat!
No you are wrong Cronic - I didn't really understand your post - but the cooler your engine, the better it will run and the less chance of detonation. Hence an aftermarket radiator to help keep water cool, and an engine oil cooler is a necessity for an Skyline that gets driven on hot days imho. Regarding the engine thickness vs temperature - once your oil is over a certain 'warm up' temperature (around 100 degrees) it maintains its highest value viscocity. So it will maintain the same 40W viscocity (in say a 10W-40 oil like I use) whether the oil is 100 degrees or 150 degrees. Obviously keeping the engine oil near 100 degrees even in hot weather or when the car is being thrashed is highly desirable - hence why an oil cooler is a very good idea.
FYI I have been using Nulon 15W-50 oil for the last couple of services and have just changed to 10W-40 to see if there is any difference. As it turns out, my car likes it heaps better - less cam rattles at startup (and in fact at all times), and the engine seems to rev a bit smoother.
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4117073
That link didn't work, but unfortunately you would have to get a different variety sandwich plate to connect to your motor, as all you want is an inlet and outlet - no hole in the middle for a filter. The normal style sandwich plate could then be used as a relocator. Best to buy a kit with a relocation kit provided - you need an extra hose and the capped off engine mount.
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4117078
the relocation kit that i have has a plate like you describe at the motor... im not sure if we are saying the same thing here... but can i put the sandwich plate for the cooler at the end of the relocation kit and then screw the filter into the sandwich plate?
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4117131
i was thinking about getting an oil cooler awhile back. i reakon get one with a thermostat, i read that if your oil runs too cool its bad for your motor. im guessing you planning on getting out on the track?
lol no worries, I was just reffering to the above comment in bold!
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4117811
Ah sorry mate, now I get what you are saying.
There is some truth in that comment though - when talking about REALLY cold oil - hence why a thermo driven sandwich plate is best - then it stays closed until the oil is up to temp, then opens and runs the oil thru the cooler.
I don't have a thermostat setup, but wish I did.
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4120080
Just to add a thermostat isn't really necessary unless you live in a cold climate place or for some reason you run really thick visc oil, as it will still get up to temp in almost the same amount of time without it. Also, most thermos don't fully close they stay partially open so as to stop air pockets forming.
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4120573
I'm still curious about this... because the sandwich plate basicaly mimics the shape of where the filter joins the block, does anyone see any issues with me fitting the sandwich plate to the end of the relocation kit, and then fitting the filter behind the sandwich plate
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4120707
It is really hard to understand exactly what you are saying mate - can you draw some pics? If I were you I would take what you got to a workshop, and ask them what you need to complete the system.
At the end of the day, as long as the system is sealed and oil can flow freely, you can do pretty much what you want.
https://www.sau.com.au/forums/topic/235057-oil-cooler/#findComment-4121035
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
