Does anyone know where I can source an R32 Gtst DoLuck kit in perth ? I have found an interstate supplier with help from Flash89 (cheers :)) but hoping someone knows of a WA based seller so I can try and avoid hundreds of dollars of shipping costs.
Cheers
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/
Not sure if ur after genuine, but Fibrevision can make it up for you. They're gona do my Origin kit coz yet again the resellers give me a quote and don't get back to me after I tell them I want to go ahead.
Which reminds me has anyone got Bruces number I need to give him a call about my kit. Had it on the old fone. Thanks :)
Edited by Magic
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4117123
Fibrevision
38 Banksia Rd Welshpool 6106
(08) 9458 8998
Tell him Brandon with the 34 gettin the Origin kit sent ya. :)
Ima go in 2moro, heck might even leave the car there and get him to do it ready for next week drags.
Edited by Magic
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4117531
I got to ask, with this fibrevision do they have the kits in stock or do you just tell the guy what kit your after and he can make it up for you and fit it? Do they also paint?
Both, in my case they have the side skirts in stock and will be making up the front/rear bars. They also do spray and fitting.
Also, if you do go in, ask to see their portfolio of show cars, you'll be impressed. Expensive work but, I'd rather pay the money and know it's going to be perfect.
Edited by Magic
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4117948
I got a Do-Luck front bar for my R34 from DMD. They are over east though. I'm pretty sure they have the kit for R32's too
Just google "DMD The Image"
isnt that monkey warehouse ?? I checked out theyre website but it doesnt work for me :S
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4118155
I got my r33 do luck kit from dmd, had it fitted and sprayed by fibrevision. So i would recommend trying dmd 07 3344 1818. Make sure they pre fit the kit before they send it. They appeared to have cut corners when they made mine which just created more work for bruce & brandon at fibrevision. Dmd are very well priced
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4118422
Got a do-luck boot cover thing for my 33 from DMD. Didn't fit the way I planned so it had to be modified and ended up costing a fair bit. Might be worth talking to Fibrevision to see what they can do price-wise because if you end up having to modify things it may be cheaper to just get them to make it the right way from scratch.
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4118810
Fibrevision get their kits/moulds from Monkey Warehouse if they are too busy to make it up themselves. Shipping on kits is roughly about $300 extra,depends on the kit of course. May as well pay fibrevision the cash and let them worry about shipping etc as it'll go straight to their shop.
I stopped in their today, My kit may be coming from QLD because they are quite busy at the moment. only about 7-10 days shipping but. kits is costing me roughly 1.7k-ish and spray/fitting is about the same.
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4119396
We have a R32 Do Luck Kit in stock, however once again we are on the east coast (Melb).
Is it for a GTR?
nah gtst mate, cheers for reply.
I tried calling fibrevision all day but i guess theyre busy lol, either engaged or didnt answer :S
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4122190
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
