hey i got ovaheating with me 25 got a hugeass ali radiator 1 10" fan run fine for weeks, put a front mount on, blows a heater hose next day, bung them up to get work next day. fix heater hoses day b4 sprints seemed fine till got out and after 3 laps steamin out the ova flow!! the water didnt look like it was flowin so figured themostat, pull the guts out a old one to get it flowin , water flows. but same shit still boilin out ovaflow wit presure in hoses. and yes i bleed the air out the top till its a constant flow. so can sumone help me out??????????
$120 tow
$free bit of hose
$150 track day entry
$123673 fuel
100 coolant look on my face priceless lol hahaa
https://www.sau.com.au/forums/topic/235377-r32-rb25/
1 10" thermo fan? is that all. i was running 2 10" thermos and was still overheating in peak hour traffic. switched to a big 16" single and didn't have a problem after that.
also have you got the fan running the right way?
https://www.sau.com.au/forums/topic/235377-r32-rb25/#findComment-4121667
yea pressure test was next, and i brought 2 10" but only one fit with the big radiator it hit the powersteer hose. and it run fine for weeks and i drive home from briss everyday to brownsplains, but would like to go biger
https://www.sau.com.au/forums/topic/235377-r32-rb25/#findComment-4121677
but u would think it would cool down wen doin 100 cruizin cause u dont need the thermo then.
You need air flowing through the radiator for it to keep the system cool. My experience is that thermos don't work on 32s. Air simply hits IC and flows down under the car. At least with the factory-fitted engine fan, it creates a low pressure area inside the engine bay, and air has to go through the radiator.
It coud also be that the radiator is too thick, and you can't cool the rear side of the fins.
Have you confirmed that the water pump is still pumping water?
https://www.sau.com.au/forums/topic/235377-r32-rb25/#findComment-4123036
the pump is def flowni cause i can see it flowni and it was put in not to long go.. i just hooked up the air con fan to me thermo see if it makes a diff tmrw :P
https://www.sau.com.au/forums/topic/235377-r32-rb25/#findComment-4124267
problem solved ,had pressure test all is good considerin it a copper gasket i t hout so, test for carbonn she sweet turns out wen i put front mount in i must put wires to me thermo backfront, opps who would thout red goes to red?. runnin low temp now max out at 90 which is pretty good sence n.o.t. is 86?........ cheers s.a, cyas on the track!!
https://www.sau.com.au/forums/topic/235377-r32-rb25/#findComment-4130124
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
