  • Replies 73
If you have had them flow tested then obviously the fuel pressure is way way over the top or the dyno is slightly out by 30-40rwkw.
250-260rwkw is pretty much max from what I have seen from the std. RB25DET injectors with a decent/safe amount of fuel pressure pumped in.
Originally posted by INASNT
u cant be serious, 6 x 370cc injectors and 280rwkw dont add up.
u r kidding yourself if you think they are the stock ones.
gtst-vspecs car is making 368rwhp with stock injectors and I think I will make near the same once I get my wolf3d ecu in.
I got 550cc injectors in mine at the moment (waiting for the new manifold and turbo to arrive) and with around 200rwkw sometimes if i change at 7000rpm, the power fc shows the injectors flowing at around 55%. Now the 550cc injectors are 130cc bigger than the stock ones each so do the maths.
INASNT, I know where you are coming from, but this is I believe one of those times that reality and the hypothetical world dont match.
With stock fuel system I was getting up to 89% duty cycle with just over 200 rwkw.
BOOSTD is at 266rwkw with stock injectors - just upgraded fuel pump, he doesnt even have an upgraded fuel pressure reg. With increased fuel pressure and a good tune it would appear that the stock injectors can go a fair way.
Too many people exeriencing otherwise to not except IMHO
Quick question, I just found a exhaust leak on my car. Its were the turbo joins to the exhaust manifold. Its fairly big. As the turbo has moved from the manifold. Could i lose power from this leak? As i said, its faily large (guessing the size but about 1x3cm - rectangular size, possibly bigger)
:uh-huh:
will have all sorts of nasty side effects. Manifolds are usually carefully designed so as to create as little turbulance as possible - turbulance can cause unwanted back pressure and cause exhaust gasses to revert into the cylinders earlier than if it wasnt present which isnt a good thing at all. And also it is probably increasing lag, as the gasses wont be going out through the turbine.
Cant really quantify the losses, but even on a NA engine with a hole in the manifold or gasket leak it can cause noticeable loss of power.
If the exhaust leak is that big it would most definitely be hurting power, also your ears... it would be very loud. what has caused the leak/turbo to move, cracked manifold?
With a leak that big the car should be driving like a pig... is it?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
