I'll be in this one for sure..
So do we have a destination set yet?
I've got a few boys who i'm sure would like to come too..One with a Rex, 200, 1200 Ute w/ CA18, few others aswell.
Is this open or just strictly SAU'ers?
RJ
  • Replies 103
Hahaha, if you're in Parramatta, it's all of 25mins away, and about 10mins more from Homebush!
those times seem to include some traffic aswell...
update, i'm not sure if i can make it for the cruise, got a friends farewell party in the city the night before and lets just say I may not be up for driving on the saturday, but i do guess i might be able to chuck an albert and show up for the meet hung over and go home when its time to head out lol
we'll see on the day anyway
haah chuck in an albert.. i like
yeah thats cool, its gonna be my last run before going to the shop :P
so guess i have to show up!
are you talking about putting that turbo in your car????? is that what you mean by the shop????
so, so let me get this straight you are having trouble downloading pornography??
OHH GET OFF THE PORNOGRAPHY WOULD YOU!!! WHY WOULD I WANT SOMETHING LIKE THAT!!
lol im lost????????????
Hey guys, it's just a meetup at this stage, will deicide to destination on the day as the weather doesn't look too promising :blink:
soft cock, pure soft.... I donno bout anyone else but my line doesn't leak...... much, only when i get the high pressure water and aim at the window seals on the door....
then again who am i to call anyone soft, i dunno if i'll be there yet lol
The meet is at 1pm Anna.
Sorry Albert, I might come up for the meet but I don't recommend driving the Old Rd with this wind, there will be sticks and small branches all over the road, always is after this kind of weather. I won't be cruising.
