i am wrecking a r32 gtst
parts are located in nsw 2321 10-15min drive from maitland
5 stud/brakes, weather shields, climate control, seats, have been sold
whats left:
bonnet $120
headlights $150-pair
bumper $50-slight damage
front reo bar $50
drivers guard $100
passenger guard $60-easily repairable damage
drivers door-$120-including glass, no trim or lock
passenger door $100-with glass-no trim or lock-slight damage
bootlid with standard wing $60
600x300x75 fmic with piping $350
turbo back exhaust including hi-flow cat-$400
tail lights $100 pair
rear bumper $50
rear reo bar, $50
gearbox $500
standard side skirts $150 pair
diff $150
tail shaft$100
dash $100
rear seat $40
carpet $100
door trims $80 pair
driver+passenger power window controls $50
radiator $100
a/c condensor $50
0411553427-Brock
there is a complete car, so anything else you need just ask,
cheers,
Brock
Edited by s13silvianissan
https://www.sau.com.au/forums/topic/236837-wrecking-r32-gtst/
cant be a roller, 5 stud has been sold,
the gear box has 85,500ks on it according to the odo,
i have driven with it and its in great condition,
no leaks or noises, goes into gears easily
passenger side power window switch/motor
gear knob (standard?)
standard steering wheel?
if you could pm with details of these items and prices that would be good.
post 2 adelaide 5037?
thanks mate
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
