  • Replies 310
Posted Images
Yay activity. Umm HI2U, your hoody isn't an XL by any chance is it?
And since we're changing the design (we'll, handing in a design) does this give people the opportunity to remove their names? I'd really like an unnamed XL in the new design if anyone is willing to swap for my L unnamed.
Oh and it may have been 6 ish months but looks like we're getting somewhere haha. Thanks guys.
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4405147
lets do this design on our blank ones!
lol Kietz when you're not being a smartass you're actually quite a valuable contributor to SAU....good job.
As I said awhile ago, that's clearly the best design I've seen so far for a hoodie.
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406499
hey damo. i sent u a pm a couple of weeks ago about sending my hoodies as they are.
cbf waiting for printing, and possibly more dramas. just send both. cheers man
edit:
d'oh :D
Tony, just checked pm, Adrian will post yours this week.
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406537
i agree with ya pete
but i was just saying that we dont want another club going around saying that we copied their idea/design
im sure they wouldnt mind, i think whoever wants the design put their hands up and we get the printing organised before it hits winter! and whoever doesnt than they can just drool when we get ours :D
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406684
Count me in then
i was just trying to be on the safe side kietz
not trying to play it down or anything mate
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406689
i rly like that design too kietz, its fkn awesome :D
i dont mind if its similar to another clubs design.
im on lates this week, so i wont be able to get mine. If there is someone that lives in the brighton/seacliff area that can grab mine that would be sweet ;)
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406756
gtrkiet's design idea looks great imo, i'd be happy to get that.
And who cares if its similar to another clubs design, they'd have boring hondas on theirs and ours will have the awesomeness of the Skyline, so ours would be better :D
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406964
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
