As title says - keen on a gig at the Gaelic Club.
Address is here
The Gaelic is situated at:
64 Devonshire Street,
Surry Hills
NSW 2011
I know jacksh1t about Sydney suburbs (except some of the generally better known ones, eg Kings X)
Gig is on a weekend evening. Anyone know if there's a decent place to park around there? thanks in advance.
https://www.sau.com.au/forums/topic/237351-safe-parking-for-gig-at-gaelic-club/
http://maps.google.com.au/maps?f=q&hl=...mp;t=h&z=16
None of the "Secure" parking places are particularly secure. There's plenty of cars that have been stolen from secure parking places before.. Often the most secure place is on the busiest street possible.. Most theives arent dumb enough to steal a car parked where there are a lot of cops patrolling for example. Although the busier the street the more dickheads walk past, and you know what that means :(
Its not the safest place to park, but its not bad. I would leave my car(r33) around there. If you have an r34 gtr or something that stands out heaps then maybe not.
As long as you hide valuables I doubt anything would happen to your car. If i park there I try and get as much of a publicly visible spot as possible to reduce risk.
The club I used to frequent was on the corner of Broadway and Harris St, so I found the best place to park if one so happened to be designated driver was behind Ultimo TAFE. Free parking in between 6PM and 6AM if memory serves me... it is on the street though and it is a little bit of a hike to the Gaelic.
Map Clicky
Granted, I only have ever parked my Skyline there once, but my mate in his FTO used to park there religiously every Friday night, no problems at all.
surry hills isnt bad anymore...
there used to be days where youd hear an alarm go off see some people running down the road, then hear another alarm go off down the road haha
I dont know what you do on the weekends but alarms are going off there every friday and saturday night. got a friend on surry street and another on victoria,,,, if its not getting stolen its just getting windows punched out by drunks.... its still too close to the cross, also good luck driving a skyline through surry hills and forget it if you have to go through the back streets and avoid lane ways at all cost, took me 5 minutes to get through this dip in a lane way, had to put a shit load of things under the front tyres to jack the front of the car up enough just to get over a stupid dip.....
Map Clicky
and id rather park my line in surry hills than ultimo behind the tafe, had my kia rio broken into twice parking there during the day while attending the tafe (nothing stolen because nothing was in the car idiots) also got jumped there by a junky and i f**ked him up so i dunno if he jumps people there anymore.... also just go for a walk on the streets around tafe, uts, braordway..... look in the gutters and on the street and you will see your answer as to how safe it is..... broken safety glass everywhere......
safest place in/near the city is the casino, at least they have security that will wonder through there every now and then because there looking for kids locked in the cars lol, no secure parking station is safe and no street parking is safe in the city, some drunk might jump on your car or throw stuff at it during a fight.....
use pub transport if your worried about the car there....
yeah I live about 80 meters from devonshire st and I have to say it's not a safe area at all. too much housing commission up devonshire st....
on the plus side the gaelic club is approx 15 meters from central station so train is easy.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
