It's Time To Party! - Tursday 2nd October - Great Northern Hotel Chatswood
Come and celebrate our birthdays at the Great Northern Hotel Thursday 2nd October from 7 - 7:30pm onwards. :/
Everyone is welcome to come along.
Don't forget your partay hats. :P:) Oh and hugs!
P.s you all better be there.. :dry:
* Chubbs +1
* Steveo
* - Sl!m (Haha!)
* Abo
thursday........ yeah probably won't be there sif do it on weeknight
ps. Corinne pls post in the appropriate section, this is an event. Dont make me report your thread to me. :thumbsup:
Well.. you're ghay! I can't do it on the Friday because it's a long weekend.. and I'm going away. Durhhh!!!
Liz Jane and I are too cool for the events section. It's not an event.. It's a invitation. Plus who the hell is going to see it in the events section!
p.pp.s LIZ JANE IS GOING TO SHANK YOU IF YOU DON'T GO!
assuming we will be there..... no arm twisting required to get us to the northern... I miss living near there :(
Might drive zeddles for a change!!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
