We are all here to get the best out of our cars and to get and hopefully share knowledge but after spending some time going through various posts It is obvious that many of the replies are total BS and based on hear-say and opinions instead of actual experience or knowledge.
Come on guys, it's great to be an active forum member but a lot of guys come here for wisdom but get no better advise that the local teen supercheap salesperson can give.
Now I'll get off my soap box and admit that I get more advise here than I could possibly give but I'd rather be of no help that to give bad advise.
Please don't confuse personal opinion for actual fact!
https://www.sau.com.au/forums/topic/237747-please-guys-facts-only/
Good call, you have just described 98% of the internet, but you still have much to learn grasshopper.
Yeah guys I knew as soon as I posted it that it was a waste of time but after reading a few posts such as where someone asked what was the best oil to use and getting answers like "use this brand cause it's awesome" or "don't use this brand cause it's crap" It frustrated me as these sort of questions are asked as a technical question and I just think that we as forum members should try to answer in a way that will help the person asking the question.
I know that this is a public forum and we should expect these sort of answers but that still doesn't stop me from hoping for technical answers based on knowledge.
It seems that most of the basics are covered time and again with the same results. The key to getting the right advice is to read alot then maybe PM. I must say that I cant really see the point of this thread ;)
What he said. Figure out who knows their shit on this forum. It's not hard. Look around. Ask again. Have a think about it. Ask for specific examples or personal experience. Ask the questions in the right way.
Why am I writing here.....? :D
Maybe this is a chance to turn this thread into something use full, who's advice do you trust?
Maybe even specify if its a certain area you trust there advice in, some are good with electrics, some are mechanical some are suspension and then you have the gods that know about every nut and bolt on a skyline.
Im going to start the list off with paul33 (or maybe paulr33) for his compiling of the power fc tutorial not to mention all the other tech refference he has compiled.
I'm also curious how you differentiate the people who know nothing and the people who sound like they know what they're talking about but don't.
For example, I read in a clutch thread (for sale) on another forum, someone said the plates had 3.3MM left (originally 3.9 or 4mm), and someone chipped in "I think that's the point before they need a rebuild".
Obviously that's not true but its the internet, you have to accept that some EVERYONE has a right to voice there opinion.
If there the forum was a community of experts they're certainly wouldn't be 1/2 this number of members :banana:
There's also the fact that people who start off without much knowledge usually build knowledge over time and often make a contribution.
Anyway, don't think this thread is going to go very far.... :)
If there the forum was a community of experts they're certainly wouldn't be 1/2 this number of members :)
Anyway, don't think this thread is going to go very far.... :closedeyes:
That would be by taking advice from someone on a problem you have and using it to fix a problem, or if that advice has helped someone else fix there problem, i was also going to suggest listing the people you dont trust but i dont think the mods would like that so i just went with the people you do trust, of which there are a few that know lots and there are lots that know a little, in the end, as mentioned earlier, its up to you to sort through the ones that actually know what there talking about and the ones that think they do.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
