hey guys,
I was on my home from the mechanic, he just changed the oil filter and oil. on my way home, there was a bang noise from the left side of the engine and now no boost!!!!!!!!!!!
on the stk guage it wont go above 0 (its like the turbos will spool up but its not getting to the engine!)
i took it back to the mechanic and we checked the vacum lines on the plenum side (from the stk boost solenoid) and they are still attached. we checked to see if maybe the intercooler hose had popped off... we cant see anything around the intercooler??
please help me!!!!
https://www.sau.com.au/forums/topic/237834-bang-noise-now-no-boost-r32-gtr/
  • Replies 43
Ive had this problem before
My turbos blew once and didnt boost after ? what tiurbos are you running and were you fanging it??, but mabye thats not your case ? also had vacuum hose come out and lastly my boost controller shat itself .. could be ???
Edited by MRGTR911
stk turbos bro???
i wasnt fanging it, i dropped it back into 2nd to go around a corner, i wasnt thrashing it :)
i thought it was the turbos but i didnt get smoke from the exhaust so i didnt suspect the turbos?
could i have been wrong?
ooh. that sounds like a dead turbine wheel I hate to say.
If you have a hose off then the car usually won't want to idle well or at all.
Dead turbine is my bet, but I hope I am wrong.
If so, fingers crossed you haven't ceramic dusted the motor. Sadly this happens alot. You will find a pot or two down on compression on a test or losing compression on leak down. If it's the turbine make sure you get rid of the oil too.
Sorry i shouldve mentioned the extremely bad idle....
it goes to stall but picks up revs to keep the car alive!
its not AFMs ive just had them reconditioned to try and fix my random cutting out problem.
so the IC pipping guys?? its a stk IC, where should i look???
thanks for the help guys!
Its pretty easy, follow the pipes from the turbos to the IC, then from the IC to the plenum. Somewhere in there the pipe will be split/loose/not sealing 100%
On my one the big pipe that goes under the airbox would always come off under hard load until i got better clamps, you might find its just a shitty clamp thats letting you down
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
