Hey guys, just a quick question about where can i get a 'VSPEC II' sticker or badge for my gtr.
Reason is my rearbar is a bit scratched and i wanna get a respray but obviously need a replacement.
Does anyone know where i could get one? maybe a sponsor or nissan?
As you can see in da pic, it looks like a badge which would be preferable to me.
any help would be appreciated.
-Johnny
ps: very off topic but i found this pic and i couldnt stop laughing.
https://www.sau.com.au/forums/topic/238172-vspec-2-badge-replacements/
GDay Johnny,
The raised V-Spec II Nur badge set-up can be obtained thru www.powerplayimports.com
or Jo-Ann at Powerplay on 02-98197555
It looks really good & classy on a friend's car further up the Blue Mtns. It has a bubbly feel to it.
Cheers,
Tez :nyaanyaa:
  • 1 month later...
Checked in fast for a vspec II badge for you and came up with the following. It seems that all the badges (Mspec, vspec, 25 gtt) come under the same part code.
Just make sure you specify which one you want if you go to see nissan.
Hey Johnny,
Powerplay can get the V-Spec II sticker or badge cheaper than Nissan and it'll come quicker too.
After mailing, it'll work out 15c cheaper; and I know how much this means to you! Tez
The V-Spec II sticker is the 'Real Deal' man. Powerplay has some inside running with genuine parts.
When I bought mine - it was more like $8 cheaper than through the Nissan dealership which said it could take 3 weeks.
Powerplay got it in 10 days.
Members also get 10% off.
I'm not sure if they can get the raised 'bubble type' that the Nur has atm.
Get Cracking!
Hey Tez, I was bout to email them but i would prefer the original nissan stuff; do they sell genuine?
citrus based glue remover called 'desolve it''
worth its weight in gold, this stuff...
Edited by HEKT1K
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
