Hey just thought i'd post up this n see if anyone's interested
movie will most likely start at 8.30
movie stars Jason Statham's
links to official site and advert here.
http://hoyts.ninemsn.com.au/movie/2915.asp
and youtube for any having trouble with the other page
blurb thingy
In the near-future, prisons are run by a corporation which uses inmates to participate in the most popular sport on earth, a brutal adrenalin-fuelled game of carnage in which monster cars are fitted with machine guns, flame throwers and rocket launchers. Former racing champion Jensen Ames is just two months away from release when the corporation selects him for the biggest event of the season, the Death Race. Facing a gauntlet of the most vicious criminals on the planet, he must kill or be killed in a brutal three day challenge for the ultimate prize: freedom.
could be corny so don't blame me if it sucks but we can be assured sh*t will blow up and cars will be gunning around n such
https://www.sau.com.au/forums/topic/238465-death-race/
  • Replies 91
Posted Images
think vu just wants an excuse to get all close like during the scary bits don't trust him people
might be on at the same session after or even at 8.30 will have to wait n see what pan's out. never know untill a few days in advance with the drive in.
last time when i tried emailing/calling it was a waste of my time no deals and only told me whats going on after i seen it updated on the webpage
^^^ tell me the last movie to come out that wasnt a sequel or remake or some variation of stuff thats been said n done before :) clearly when any and i mean any movie that comes out has 2 more follow it they are running low on ideas. just thank god theres no follow up to broke back mountain or any attempt to copy the idea.
i have no doubt fast n furious will prob have 5 more editions to come after part 4 comes out mid next year.
also note there is no RB26 in the mustang in this movie :D
Edited by Inline 6
https://www.sau.com.au/forums/topic/238465-death-race/#findComment-4168851
just downloaded the new fast and furious preview off torrent, looks pretty cool there hijacking fuel trains worth 1.4 mill. and all the good original people are back in , good old Vin and the hot chicks. and the charger with the supercharger hanging out of the bonnet. and Blue R34 GTR etc. wish it was out now, instead of 2009,,,grrrrr
that should be a mandatory club event...lol
https://www.sau.com.au/forums/topic/238465-death-race/#findComment-4168923
http://au.movies.ign.com/articles/901/901383p1.html
review for anyone interested 3.5 / 5
yeah jenkies you better bring your R out or ill key that sh*t
steve that game sucked ass.
think of it as road rash with cars :( skitchen was always cooler though. being a rollerblader im biast on this issue :P
the movie title contains 2 of every one's fav words in movies :( death and race come on its gota be good
Edited by Inline 6
https://www.sau.com.au/forums/topic/238465-death-race/#findComment-4173495
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
