Here's a full wide body kit...Dontknow how wide the fenders a though. What you guys reckon?
that is a pretty wild kit, any idea who its by? or is it custom
True that, the widebody "kit" needs to be moulded to the body of the car, not just stick out.. looks like someone grabbed some peices of metal and plastic and glued it to the side of the R34.
MRXTCZ
kinda have to agree sadly, i think moulding it to the body would help heaps
2800 for the whole kit, front bar side skirts rear bar and wide guards or 2800? widebodying a car is pretty expensive alota time involved gota pop rivert the guards on grind of the head bog over the top then sand back down
  • 1 month later...
  • 2 months later...
hey
anyone know how i can get my hands on that Cross Factory kit?
anyone bought it or know a group in melbourne that could import it?
any help would be good, cheers
www.rhdjapan.com sell it,
I hope you have deep pockets, expect to pay around the 10k mark delivered for the full kit, not at all a cheap one, that is the only place that i know of atm that sells the kit
10K... ur way off its only AUD 9518.49....... lol DAMN!
looks like ill have to cut my losses
thanx anyways
lol, actually, we are both off, its $10,387.87 for the whole kit, you must have missed a piece lol
the kit is made up of...
Side Skirts - AUD 1550.08
Rear Bar - AUD 1642.63
Wide Rear Guards - AUD 1935.23
Wide front guards - AUD 1739.47
Front bar - AUD 2098.90
Front bar Lip - AUD 1403.56
totalling AUD 10,387.87 shipped.
see link below for each part
cross factory kit from rhd!
This is a personal favourite, hopefully what id like to eventually get, its a West Yokohama kit:
Its a kit for GTT's dont need to replace the bonnet and it looks like the GTR bumper. Its also not mega low which is a bonus for a daily. Only thing is i dont know of anyone that sells it here in australia.
Ive got a pic of the bumper on a 4 door r34 that looks hot, hopefully post that up as soon as i can find it.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
