I'm looking at upgrading the injectors on 33gtr as stock ones are maxed , spoken to different shops and get different advise, one says hks 640's but that means have to get hks feul rail also $$$$$ and they say sard 700 aren't very good, because they are twin spray and over feul when you put your foot down ,with big puf of smoke out back.. but seems to me lots have them ,, anyone experience this and what about economy ,, I curently get about 350 to a tank..
btw only after about 420-450 awhp
https://www.sau.com.au/forums/topic/238503-injectors-upgrade/
Nismo 600cc's should do the job, they are a straight drop in and you don't need to modify the fuel rail.
I also believe that they have 3 or 4 tiny spray nozzles which distributes the fuel better, as a finer mist leading to a more efficient combustion.
Edited by GTR-PWR
You can pick then up new for much cheaper than that buddy, try nengun.com or http://www.greenline.jp/ delivery takes a bit longer but it's worth it if you can hold out :P
holy s##t what a gold mine .. thanks heaps for that....for those prices I might as well get nismo
now I don't have to get robbed locally
cheers
I'm guessing you have an aftermarket ECU.
Why not get an aftermarket adjustable FPR, and bump the fuel pressure a few psi?
yes have dejetro
No body's mentioned FPR to me , just told I need to upgrade injectors... What is FPR etc
and yeah I've sent a question about those prices.. 1 or 6 ??
fpr is much cheeper than new injectors if u only need a little more and u can simply increase the fuel across the hole tune but winding some pressure in
but if big power u chasing then injectors it is
ok just read a few things about feul pressure regulators
If getting an adjustable FPR and upping the pressure is sufficient why does everyone change injectors ??
injectors are at 90 -- 95% at the moment
running 380 awhp with injectors 90 -- 95% looking to go for up to 450 awhp certianly not mre than that....
do you think thats poss. with just FPR upgrade
thoes prices per injector?
yip those prices are per injector....
am still going to get a set of nismo probly 600's uncase I decide to turn it up some more...
thanks guys for the info,, just goes to show its worth asking around and not just taking the word of one shop..
and nismoid they were the ones doing the work on my car ----- from now on I'll be doing my own researth.........cheers :(
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
