Hi!
There will be snow i Norway soon, so now im going to do a oilservice before i put it away for a couple of months.
My brother works at a local benz dealer, so I`ll get 50% off castrol oils.
What do you recomend i use in the gearbox and in the reardiff?
Im going to use castrol edge 0/40 in the engine.
I have seen that redline if often recomended, but i dont have an 50% discount on redline. And if im going to use it i have to order from us og england (expensive)
https://www.sau.com.au/forums/topic/238914-gearbox-and-reardiff-oil/
Straight out of the Castrol website using their lube selector. This is for a R32 GTR btw, I don't think the 33 GTST is listed there. Faily sure they are the right ones, but you may want to call Castrol to confirm.
Engine:
CASTROL EDGE SPORT 10W-60
Gearbox
CASTROL VMX 80
Power Steering
CASTROL PS FLUID
Diff
CASTROL EPX 80W/90
4WD Transfer
CASTROL TRANSMAX Z
Edited by __PhaseShiftDown
  • 2 years later...
syntrax for gearbox and diff. GT-T with the standard viscous LSD will be fine as viscous is a sealed unit. If you have A-LSD then you need a diff oil with friction modifiers in it.
definitely go synthetic. I had motul gear 300 in my diff and after 80,000km and a couple of texi days I dropped the oil and it was still honey coloured and smelled great.
ok thanks but the LSD fluid is slightly thicker would that matter
ahh and also how can i tell if i got a LSD or a viscous LSD ?
  • 1 month later...
for 32R diffs, is there a difference in oil used between front and rear diff
i see CASTROL EPX 80W/90 is recommended by Castrol however other threads also recommend Castrol SAF-XA Limited Slip Rear Axle Oil - 80W-140 (apparently due to different conditions between Jap and Aus)
Hi!
can you get Motul Ow 30 or say Agip 5W 30
on the topics of gear oil, I just had my GTR gearbox rebuilt with new synchros and seals. It has a OS Giken gearset in it and I am still contemplating which gear oil to use . . .
I am deciding out of Redline Shockproof Light and Royal Purple Max Gear Oil. Any recommendations on these two??
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
