Well I finally got my stroked rb20 running yesterday but as soon as it started could hear she wasn't firing on all cylinders, We tested the injectors there all clicking away, took annd the coilpaks out and earthed them all with the plus in them and spun the CAS and they all spark.
I am stuck for ideas why its not running correctly, can anyone shed any light on why or what could be causing this to happen ?
Cheers
Cameron
https://www.sau.com.au/forums/topic/239019-r32-running-on-4-or-5-cyl/
Igniter? coil harness?
Did you unplug each coil one at a time to narrow down which cylinders weren't firing?
Of course Bubba,
Tried each injector, and each coil pack on top of the engine and they all sparked.
Number 3 isn't firing whilst unplugging while running the engine.
Yes but they all don't cover all the injectors working fine and all the coils sparking and all brand new plugs and it still does it.
is the spark a good spark or just a spark, as if the coils are worn or the harness is stuffed they will still spark yet not properly, also have you checked the timing?
Coils are brand new used them for all of 1km driving before the engine came out. I am thinking its in the harness or the ignitor I had a quick search but is there nay way to test the ignitor?
Timing is spot on the mark.
The principles are the same.
If #3 isn't working, then they are not "all fine". To repeat the several squillion threads, it's simply a matter of moving / swapping component locations to determine which part of the system is kaput.
And to add, We have switched the coilpacks around and the problem stay on number 3, we have also switched the injectors around.
I have read countless threads where Coilpacks are stuffed or sparkplugs are fouled up..
This case is different, I have even tried 3 sets of brand new spark plugs, 2 sets of coppers and 1 set of iridium's
We tested all the coilpacks at once but earthing them all along the top of a peice of steel earthed ot the car all of them fired when rotating the CAS, we did similar with the injectors only plugging one in at a time and spinning the CAS they all make the clicking sound when they fire.
I wouldn't of made a new thread if this was like the "squillion other thread"
The things I am yet to try is a different ignitor and different harness but have tested continuity from the ecu harness to the engine bay and all check out fine even while jiggling the harness looking for loose or broken connections.
And to add, We have switched the coilpacks around and the problem stay on number 3...
These 2 statements don't correlate. Either they all work, or #3 has a problem. Which one is it?
Yes, This is why I don't know why its not firing... They all sparked yet when you run the engine number 3 doesn't fire this is my problem.
Understood that if the coilpack didnt make spark to try another and see if it sparks, but what happeneds if it does spark? and changing to another coilpack still provided the same spark yet when its all on the engine it doesnt fire it?
Ok, so while you are testing the coils, they are at a different angle to when they are "installed". That might suggest a fault in the wiring to #3 coil. Have a play with the wiring to the coil while the engine is running, see if that has any effect.
Ok well, Seem to have found the problem being the number 3 injector... I took it out because it wasnt functioning.. put 12v on it no clicks... tapped it a few times tried 12v again and it started to click again. Hopefully when I put it back together it all works fingers crossed
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
