hello
there is very little difference in cost between hiflowing a turbo and rebuilding a turbo (ball bearing)
both steps throw out all of the junk and replace them with new items
its just with a highflow they put in larger flowing items and bore the housing out a little
when you recondition a turbo they put in new compressor and exhaust wheels
balance the bearings, new bearing pack (chra) and make all nice and schmick at 100,000+ rpm
so if you gettting a turbo "reconditioned" you would be silly to not highflow it for the extra $300 ish ?
that being said you can get your turbo reconditioned cheaply but it might not be balanced properly
or they may re-use the old existing wheels and just replace the bearings in it (which may be acceptable too, ask a turbo shop?)
https://www.sau.com.au/forums/topic/239100-turbo-rebuild/#findComment-4178663
i guess it must be the price for Hi Flowing the unit cos they are replacing the wheels with steel items and are maching the housing cos it was damaged when she went bang!
Weeellll, I took mine to be HiFlowed at RE Customs (only guys in Australia or NZ to have removed the turbo on an M35 Stagea without dropping the engine).
I don't know where they sent my turbo to (somewhere in Dandenong), but it cost ~$1100 and now uses a T3 core.
Add labour charge on top of that to remove/install.
If you can do it yourself, just ask one of the guys at RE where they send their to. Can't hurt.
Edited by iamhe77
https://www.sau.com.au/forums/topic/239100-turbo-rebuild/#findComment-4179293
there would have to be over 100 threads in the forced induction section on here on highflowing a turbo, the costs, the info, gains, back to back comparisons, charts, wheel specs, various places to do and a stack of other info
https://www.sau.com.au/forums/topic/239100-turbo-rebuild/#findComment-4181619
ohh ok , thanks for the reply, did you feel a big diffrence? like did u feel the geforce? how much PSI was it boosted to? did it feel good? did u feel like it was worth it. because im very keen..
Ok, in order...
No problem.
Yes.
Yes.
It was boosting 0.8bar @ 3200rpm (which is standard for the stock turbo), but now boosts to at least 1 bar @ 3800 (exhaust allowed it to breathe). I say a minimum of 1bar because my factory boost gauge only goes to 1bar.
Ooh yes :D (Brad made the comment that it is by far the quickest wagon he has ever been in. I just don't know how many performance wagons he has been in :blink: )
Didn't really have a choice, but definately.
Talk to Ray at RE 03 9548 3414
Edited by iamhe77
https://www.sau.com.au/forums/topic/239100-turbo-rebuild/#findComment-4183473
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
