Ive actually never done this event with semi's!!
Last year I took them up but the tyre shop stripped two nuts so I couldnt change tyres, I was still 3 seconds quicker than the year before on street tyres!
You got to remember that your semi's wont warm up as quick, and when they do, your run is over :P
but in saying that, I'll be in semi's....whether its the street semi's of the falkens or my old, shagged r888's
  • Replies 251
Posted Images
Oh noes its Geoff!!
Bring it mate, bring it hahahah
Oh, Pete with the VE SS in your hockey team? Gee him up to get his butt into gear and enter!!
http://www.blcc.com.au
ENTRY IS NOW OPEN!!!!!
main page you'll see entry forms and supp regs, print them off, read,fill it out, send away with a cheque :D
lol
yeah mines sent. I faxed copies cause of steves reason, cause Im super dooper keen haha
Also, just a reminder, prob best to get your accomodation sorted soon too.
Hey Fellas,
Day 2 looks good, but how is day 1 run? You do a sprint down conrod from forest elbow with two cars at once? side by side? Stange concept.
How quick does it book out? I need a few weeks to have some car changes made and have a test run at QR before I book in.
cheers
Michael
Hey Michael!
Would be good if you can make it!
It can sell out pretty quick, within a few weeks.
The conrod sprint...(here comes an essay! haha)
There are 4 groups.
group 1 goes up from the pits, up conrod. you get 3/4's (most of the way actually) the way up, and you do a u turn at the bathrust light car club home driveway. you then go back down
conrod a bit, break into 2 lanes.
Its hard to describe, but with conrod, theres one ditch, go up a hill, and then it goes into the chase?
You basically start at that ditch on level ground. You can do a skid to warm up tyres (cant get on the brake though!)
Then bascially its a drag race - up the hill, then down into the chase.
through the chase, obviusly the quicker car would get the better line, unless they are waaaay in front!
then into murrays, and go across the start finish line and thats it!
then the next group goes up and so on!
For us liners - we are class SV over 3000
Last year we spoke to the organisers and I think they will allow us to enter in Type 2 or 3 over 3L. It's crazy to say that an R32 GTR can be type 2 but an R33 GTST is SV.
That said, I am out. I've just bought a track bike so no dosh for this.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
