hey guys
i know its been covered before
however
i bought a JVC KD-AVX11 in dash dvd player
just thought u should all know that anyone with a xanavi head unit can use this deck
it switches to ntsc mode and playback through the xanavi screen is perfect
heres a link to one
http://www.digitalhome.com.au/Car_Sound_an...VD_Player/21975
Ryan
https://www.sau.com.au/forums/topic/239325-dvd-in-stagea/
So it was a simple install? Have you got pics?
Cheers.
hey guys
however
heres a link to one
Ryan
https://www.sau.com.au/forums/topic/239325-dvd-in-stagea/#findComment-4181334
i've got a similar deck from JVC for anyone that might want one
http://support.jvc.com/consumer/product.js...elId=MODL027409
pm if interested
i planned to do exactly what you have before i got my stag however mine didn't come with the xanavi screen so kinda pointless
https://www.sau.com.au/forums/topic/239325-dvd-in-stagea/#findComment-4181759
im so awesome :)
i can change the channel when the car is in tv mode... too bad i dont have a tuner... ive looked at this one for a while
http://www.marinedirect.com.au/catalogue/c1968/p101984
if there is a plug that connects the rear of the xanavi head unit to the old tv tuner, that changes the channel... i think you can get an adapter to plug into the rs232c plug at the rear of this unit, which will mean you can navigate through the channels as if the car was standard :D... hopefully :(
and its for marine use so it should have pretty good pickup
Edited by Space Goat
https://www.sau.com.au/forums/topic/239325-dvd-in-stagea/#findComment-4195039
My system is a bit cheaper than that, it must be said.
but instead of outputting to an LCD, I decided on something more ambitious...
that 12v outlet in the boot is really handy for a projector. (once again, I apologize for the lo-fi pics)
https://www.sau.com.au/forums/topic/239325-dvd-in-stagea/#findComment-4195797
lol, thanks. It's the upside of being a techie, I guess. Having access to that sort of equipment.
Obviously with that sort of arrangement I can't watch anything while I drive, but with a car like this, why would you want to?
https://www.sau.com.au/forums/topic/239325-dvd-in-stagea/#findComment-4198364
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
