So I recently destroyed my Garret GT30/71R (I think it sucked in a small dog or something).
So instead of spending large amounts of cash rebuilding it, I am considering an upgrade...
I have the following mods done to my RB25DET:
- A'Pexi Power FC
- Splitfire coilpacks
- 550cc Sard injectors + 044 fuel pump
- Turbosmart Supersonic BOV
- JJR Front Mounted intercooler 300x600x76
- Trust Power Extreme ll 3" full exhaust
(I will also be installing a GReddy Profec B Spec ll boost controller)
Using the previous turbo the car made 240kw at the wheels, I would like to see it make 260 - 270kw on a safe tune.
I am looking for experienced peoples opinions on what turbo I should get.
I am also going to use the standard exhaust manifold so high mount and/or external gated turbos are out.
Any help will be much appreciated,
In my original post I said that I am not looking for high mount and/or external gate... But thanks :P
sorry for my ignorance :P
well my friends R33 has a low mounted GT3040 on factory manifold and is making around 270kw at the wheels on around 1.3BAR with cams and PFC.
Edited by dmr
No problem :P
I didnt think that you could low mount a GT3040 (I thought that they were too big), but anyway... Would a turbo that size be very laggy? I dont have aftermarket cams in mine either.
no idea on how he got it to fit, he brought the car with the turbo previously installed. he gets full boost at around 5,500rpm.
i fit a TR43 (almost same size) on my RB20 low mounted. i had to grind back a millimeter of the manifold and rotate the turbo housings a couple degrees.
Edited by dmr
GT35... look below for my results...
I had my GT35 low mounted on my customised factory manifold...
if you want a big turbo it's a good choice...
Not bad at all, Im assuming that the GT35 is external gate?
Sounds like it could be an option, I think I would prefer to have something a bit more responsive though. The GT3071 had almost no lag at all :P
going the hks route will be very expensice but the 2835 pro is great.
Garret is the way to go but to get that power with a good setup you will need a external wastegate as the internal setup doesn;t work so well with the garret turbo's.
The turbo you have should do that.
So just rebuild it, problem solved. If you CANT make that power something isnt right with the setup.
The 3071 is the perfect choice!
GT3540?
Why put a 700hp turbo on a car thats only after less than 450hp? stupid suggestion
You can actually get them with internal gates, no problem there... however again, its a dumb turbo choice as is a GT3040 even in the 500hp form (with the smaller comp wheel)
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
