Will R34 fit on the 32? I got a lockbar on so don't need them, although the arms are still on my car...
cheers but id guess they are different. ive had an isc lockbar for 3 months but i just been to slack to fit it!
34 lockbar won't fit 32.
Try Japanese Performance Centre in Osborne Park (9201 0400 I think).
P.S. So what did you hit?
P.P.S. Throw a lockbar in there :)
got the lock bar already. damn i regret not fitting it months ago... it got a bit confusing with the whole hydrolic lines bizzo... i was planning on just plugging the 2 lines at the back but i kept reading conflicting diy's on a few forums with having to remove the whole system from the front or looping the lines at the back (also there's no fun in paying someone to do it) so i put it on the back burner.
An unpright curb was the culprit, pulled it back around enough to washed off speed but the rear wheel hit nice and square and came out ok.
I removed most of the suspension and dropped the exh to have a good look at the diff, running gear and main structural areas of the subframe, measured it all up best i could and inspected all the welds and looks fine.
You don't have to remove all the stuff to the front. I didn't when I first put my lockbar in, you just loop the lines back on themselves. When I last had the motor out I took the opportunity to remove the lines to the front along with the big solenoid thingo in the engine bay.
hicas lock bar FTW, ive some problems with my hicas too. .. the light comes on and off now and then and i lose my power steering .. its a real pain .. sob sob .
Can't help there.. 33 systems are different. Things like fitting aftermarket steering wheels can affect hicas (if it's not on straight or you've damaged teh steering angle sensor). In a 32 that would be more speedo cable related but 33's have electronic senders and the HICAS isn't hydraulically controlled.
Anyone have any tips on getting the alignment arms from the hicas off the wheel hub assembly??
i've tried everything i can, different angles, pryed, supported wheel hub at different heights and beat the bajeasus out of it to try and knock it off the damn thing.
the good arm has been removed totally from the hicas and even then i still cant get that one off the ball joint thing...
just with standard hydraulic hose and clamps?
was told recently the pressure was too great and i would need pirtek to make up some high pressure fixings or something to hold the hose on.
I just reused a bit of rubber hose and clamps that were already located somewhere on the power steering circuit, can't remember exactly where.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
