  • Replies 56
Originally posted by Ryan D
i must be the only skyline driver that listens to heavy music :D
Hell no, I listen to bugger all else (unless my GF is choosing the tracks :D )
Rob Zombie and White Zombie (and the remix albums) are probably the no. 1 chart hits in my car.
cheers,
floody
These are the Initial D Soundtracks I picked up on my trip to Japan.
Initial D - Battle Stage OST
Initial D - Best Selection
Initial D - First Stage OST
Initial D - Second Stage OST
Initial D - Third Stage OST
Initial D - Selection Vol 1
Initial D - Selection Vol 2
Initial D - Selection Vol 3
Initial D - Super Euro Beat
Initial D Second Stage - SPECIAL NON-STOP
Initial D Second Stage - Vocal Battle
Makes for some good cruising tunes :D
"Speedy speed boy ! " lol
cheers,
floody
Can't disaggree there mate. I only listen to Punk/Rock mainly.
Scott
Originally posted by a5h
Evanescence - Going Under
Evanescence - My Imortal
and
Evanescence - Bring me to life
yay! top40 rock kiddies!! :) :)
I should add to what I said above,the Monster Magnet album "God Says No" gets a lot of play in my car.
cheers,
floody
  • 7 months later...
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
