Just out of curiosity, why do you want to remove it?
If so, I think its a bit of a job as it is mounted to the engine block and you'd probley have to move afew bits of your piping and belts to get it off.
If your doing it to save weight, remove your airconditioner.
https://www.sau.com.au/forums/topic/240230-what-is-this/#findComment-4202138
Title says he just wants to polish or paint it.
I wouldnt bother trying to take it off to paint or polish it.
You would have to take off too many things to make it worth doing
My bad.
I probley just mask everything up and just spay paint it where it is. LOL!
https://www.sau.com.au/forums/topic/240230-what-is-this/#findComment-4203182
You mean you wanna make it look like this? ;) Its not that hard to remove. You will need to undo the 2x bolts that hold it to the bracket on the block/head. Once they are loose you will be able to take the belt off the power steering pulley. Then remove the feed hose from the reseviour, and the High pressure line/s. 2x if you have HICAS. It will drip a fair bit of powersteering fluid so do it over a catch tray and degrease after your done. Make sure you have some P/S fluid to fill it back up.
Deren
https://www.sau.com.au/forums/topic/240230-what-is-this/#findComment-4204850
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
