  • Replies 225
Posted Images
Wow another big SAU roll up. Not to hot lathugh may be a little wet. As always it willl be an interesting day.
Thanks for having us again John :yucky:
Looking foward to seeing if my car does any better now.. I think she is healthy again.
Now I can go and wash my car tonight so it looks healthy too lol.
this will be a top day. everyone should get out there. cheap way to get your car on a dyno and see how it's going. :banana:
I will try and make it out too. the only question is do I bring the 34 (stock)? the S13 runs about 230odd rwkw on UAS dyno so maybe I should bring that? or I'm kind of curious to see what my FD RX7 is making now that the new pre-stage ported 13B is run in. hmmm tough choice. I'm guessing the stock 34 GTR makes about 190rwkw and the 7 maybe 200rwkw or so.
well if I don't make it out, have a great day without me guys. :D
if you can't decide i'll take the RX7 for you lol, they are a beautiful machine, completely different to the skylines but in its own right they are excellent. A friend of mine is actually looking at a 1991 series 5 turbo on sunday, what should he be looking for?
I'm washing my car anyway because a few days ago while going throgh the m2 tunnel those bloody stupid exhaust fans splatterd oil on my car, couldnt wash it because i was going to work, then i finish work at midnight, wake up for work next morning, finish work midnight again, so gota wash it now....
and if its 20-25degrees tomorrow the temps will be ok for the dyno results, cooler air = denser air, denser air = more air, more air = more power lol
if he's buying an old RX7 my advice would be pay as little as possible and save for a rebuild! mine is a 2001 RZ and even it was due for a new engine after a wee 30,000kms! rotor motors are not built to last. :banana:
can i still come with a broken three gear you only need fourth gear for a dyno run
If we get you rocking up scobles, you have easy takings of the RB30 trophy. Was your run on the Envy dyno with gas? Impressive figure. :banana:
Cyas tomorrow.
im out :) i found the limits of a standard rb30 bottom end engine let go at 592hp not bad for a stock engine time to visit abbcos ha ha or i mite build one for once ;) just think what we can make with a built engine 600hp+
If we get you rocking up scobles, you have easy takings of the RB30 trophy. Was your run on the Envy dyno with gas? Impressive figure. :O
Cyas tomorrow.
nah the run on envys dyno was with no gas just 20 psi should have left it there but where do you stop
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
