Spotted TWO06L in the current HPI magazine on page 66.
Darker colour though now as to when it was front cover of same mag a while back.
clever car that...how it changes colours...its silver again.
oh no that wasnt TWO.06L.... that was TWOOGLE... hahaha... silly magazines... hmm gtr with 26L plates... nah it must say twoogle
saw a nice blue r32 gtst past sandgate this morning.
also saw a kickass hachi trueno at avalon yesterday and saturday... pig.513 (guess he used to own an s13) plates, longchamp rims, bride seats, nardi wheel, white with a matte black bonnet... classic look.. there was a green levin aswell, with mismatch rims... looked awesome.
cheers
Linton
Haven't been on here for ages so I didn't know this thread existed - but yes I own the "other black R34 GTR vspec" in newy - with the Silver LMGT4's :)
Saw a blue R34 GTR heading towards Koorangang yesterday arvo on the way home from work. I was in my mate's 31 at the time so he prob wouldn't have noticed me :D
cheers
Linton
Silly you...it was TWO.06L plates...how do i know...because they were mine.
Its a clever car that changes colours depending on whether its racing drags (silver) or circuit (gun metal)...lol
Can i join the newy R34 V-spec club?
Edited by DiRTgarage
saw a yellow s15 and a black 33 heading off ash island then again in darby street on monday
and how many R34 GTRs are there in newy?
i thought there was only 2 or 3
As far as I can tell there is 3. Rysith bought his a few months before I bought mine and there is the Blue one.
So 2 black and 1 Blue.
Anyone seen any others?
Blue V-spec should not be too far away...
not sure if anyone else seen a dark blue or possibly very dark purple one around or i am just imagining things?
are you still going down to autosalon bakes?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
