spotted silver 4door 32 and white 31 heading northbound past tuggerah round 4 45 this arvo. twas in the dv11sh mobile. i whipped out my lanyard thing and got waves back.. yeww
That was me in the R31 :down: And my twin bro in the 32. I'll get him to post up here.
DV11SH makes me want a Black R34 4 door very much :) Looks awesome.
Oh hey that's you!!
Yeah I had an SAU sticker sitting right next to me but by the time I picked it up you were waving to my bro in the 31 lol. The Black R34 4dr looks mint! I saw it in the mirror from a while away :)
-Jimmy.
spotted the DV11SH mobile, green car park at Erina Fair bout 5:20
Spotted Tinks the teh POV031 when i was leaving bout 7:20.
Too lazy to make it the plaza for the meet
Spotted a very nice looking Bayside Blue R34 GT-R go past work (Heatherbrae) today, i was chucking a U-Bolt as it went past, anyone on here?
sorry i didnt wave, i was trying to hold my jaw up :P
spotted a heaps of Skylines out and about today. most memerably would be Sl!m with the incredibly bright wheels, seen you from half a k away lolz you were at the round-about near Lake haven shopping center about 2ish
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
