Spotted T4NK down in sydney last night, heading north I think. Was a BB R34 on white rims, with an offset plate anyway!
haha yep i was on my way home from work, then i had to go back to manly to pick my dad up... where u in the bayside blue 34 that i passed on the pacific highway just after/before Turra?
Spotted a dark blue 33? (I think) with white mags at Wallsend this arvo
Just a word of warning if I see you driving again like you did today I will report you to the police.
Roundabouts are NOT for drift practice and a super loud exhaust does not make your car go faster, it only makes you look and sound like a tool.
Tank, is that your gtr parked...well was
Parked next to my i30 at payment fitness?
um, im not sure, i go to plannet fitness at West Gosford, if that was where u saw it then yes it was, white on blue, looks like a mirror atm, waxed it like one of my french girls.
spotted a maroon R32 the sarvo at south kincumber..... didnt get a wave back :/ always akward when that happens..... haha and the misses goes who was that LOL
and a black R32 going up the central coast highway going passed avoca drive on saturday i think.......... either high 2nd gear or high 3rd gear on full boost did sound pretty tough as you went passed!
Clean your white wheels tank haha
Yeah was your car!
i cleand them last saturday....... i clean them drive 50km they are black again, bendix pads are shit house, getting some QFM HPX once im paid in about 2hrs.
Haha my mx5 wheels were white, too much brake dust and like you cleaned all the time. I gave up and painted them black! Easy as now!
Qfm's are great!
and yesterday arvo at daleys point / empire bay a white r33 gtst i think, plates HER25T, and im pretty sure a chick was driving.... go figure!
thats Ella, she's mad
spotted a white 34 GTT at Killcare Beach on christmas day and exchanged a wave with the driver of a white series 2 33 in Kincumber this afternoon
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
