Andrew Sanders at Specialised Power Porting is the only place in OZ that I understand currently does this.
I have used his services on my exhaust manifold, intake manifold and compressor cover. From memory, 4 cylinder manifolds (intake or exhaust) were $550 each and comp cover around $300. Obviously these prices may have changed and will be more for 6 cylinder manifolds.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4206860
Based purely on a power figure I'd agree, but has anyone measured the efficiency maybe as a fuel consumption figure?
If something flows better, it has to have benefit somewhere, even lower rpm for boost gains maybe?
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4207799
One of the advantages is extrude honing allows you to flow balance each runner as well as improve flow overall. For instance my sr20 intake manifold was all over the place and when extrude honed the runners all flowed within a few cfm of each other. Not to mention it also picked up nearly 50cfm of flow on the poorest flowing runner. Unfortunately I had a change of heart and am now installing a Hypertune manifold so I can't say what the real world results might have been with the extrude honed unit.
Edited by juggernaut1
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4208624
When I rang this place (about 15 months ago) he no longer did extrude honing as he had leased/sold his dies and gear to someone else. I think Unique Autosports used to use his services because when I ran Unique about the same time they also advised me they were no longer able to get manifolds extrude honed. Things may have changed now tho'.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4208892
There was a thread on an extrude honed RB25 stock exhuast manifold and no real gains were recorded. Most likely the money can be better spent elsewhere.
Yeah that was my little experiment. From what i learned it depends on what turbo/power your going to run which will help you decide if honing the manifold will be worth it.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4210442
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
