Andrew Sanders at Specialised Power Porting is the only place in OZ that I understand currently does this.
I have used his services on my exhaust manifold, intake manifold and compressor cover. From memory, 4 cylinder manifolds (intake or exhaust) were $550 each and comp cover around $300. Obviously these prices may have changed and will be more for 6 cylinder manifolds.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4206860
Based purely on a power figure I'd agree, but has anyone measured the efficiency maybe as a fuel consumption figure?
If something flows better, it has to have benefit somewhere, even lower rpm for boost gains maybe?
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4207799
One of the advantages is extrude honing allows you to flow balance each runner as well as improve flow overall. For instance my sr20 intake manifold was all over the place and when extrude honed the runners all flowed within a few cfm of each other. Not to mention it also picked up nearly 50cfm of flow on the poorest flowing runner. Unfortunately I had a change of heart and am now installing a Hypertune manifold so I can't say what the real world results might have been with the extrude honed unit.
Edited by juggernaut1
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4208624
When I rang this place (about 15 months ago) he no longer did extrude honing as he had leased/sold his dies and gear to someone else. I think Unique Autosports used to use his services because when I ran Unique about the same time they also advised me they were no longer able to get manifolds extrude honed. Things may have changed now tho'.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4208892
There was a thread on an extrude honed RB25 stock exhuast manifold and no real gains were recorded. Most likely the money can be better spent elsewhere.
Yeah that was my little experiment. From what i learned it depends on what turbo/power your going to run which will help you decide if honing the manifold will be worth it.
https://www.sau.com.au/forums/topic/240906-extrude-honing/#findComment-4210442
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
