good waste of time :P lol did it... car didnt run bad but revs did drop after a huge flutter... was pretty sick but y fuel economy would half if i left it there!!! soo addictable :P good for a laugh but dont wona get looked at ne more than i need to
  • Replies 188
I've ran mine since I can remember with a blocked off BOV.
With the ceramic turbo running 1bar I covered around 100,000km's on the rb20det, then pulled it out for the rb30det. Still in good nick. I went a VG30 which was good for another 50,000km's and was still fine when I pulled that off, the Garrett gt30 I now run still doesn't use a BOV.
The GT30r has covered around 40,000km's now. Damn time flies. :S
The bov is there for emission reasons. Without a bov look what it does to your afr's on and afm voltage as you come off the throttle which causes stalling, back fires and some times flamage. Another issues is the strain it puts on your joiners/clamps. I had to replace some with t-bolts.
The reason I went no bov is the stocker was for the part throttle drivability. No bov you grab the next gear and boost is just there. Without a bov it felt laggier on gear changes as I presume it takes longer to fill the FMIC and piping than it does to regain the 'slight' speed the compressor may loose due to pushing against a pressure source.
Shaun/Boostworx runs track cars with no bov, no issues related to no bov. I know of multiple high powered RB30et's without issues running no bov.
No more need to be said!!!!
  • 2 years later...
Okay, old thread here. sorry, want to blank off my bov so I dont look like a fag when I drive around. Used search came up with this and a heap of old closed threaDs that seem to make it sound like IF u blank of ur bov it just makes ur car get that other gay flutter noise not silencing it completely. Is this correct?????
you own a turbo car but dont like the bov noise? have you got an aftermarket bov?
yes, if you block it off it will flutter.
Did have an aftermarket atmospheric one when I got the car which said LOOK AT ME, then swapped the mechanic who took it through regency for me for his stock one. But its still too loud oh well guess Ill just have to put up with it in exchange for a nice fast car.
The one that was on it also made a fluttery type sound when u gave it a rev.........I dont know fark all bout them though
you probably had an adjustable one, where you can stiffen to spring so it only vents a small amount of pressure and flutters the rest. if you have a pod, try fitting a stock airbox to quieten the induction noise and see how you go
Just out of curiosity.... everyone is saying use coke cans, mountain dew cans etc. Are they being used as blanking plates? Not entirely sure how its done.
I've got a 32 with an rb20 with an aftermarket BOV. Was just wondering what the deal is with making up blanking plates and what everyone has used.
As Damo has mentioned earlier. You cannot have a turbo car with a pod filter and not expect any induction noise at all. Even with the stock BOV it makes a loud woooosh sound. But if you block/blank it off all the pressure has to go somewhere and since the BOV is blocked it will just go back through the system hence why it makes the huge (in my case) flutter.
Totaly acceptable use of thread bump guys
Take your bov off grab a pen trace around it and cut coke can up a good pair of scissors is all that's needed
Presto spot on Steve. I have been using a coke can pretty much since i have ever owned the car lol
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
