Took it for a run on PRIVATE PROPERTY (cough cough) and it sounded great... none of those stalling issues either...
As mentioned in above post, you can drive it softly with no flutter and if you want it to flutter just give it some stick!!!! :)
All is good...
(now to take it off so that i can drive on the public roads again withought being defected by the boys in blue....)
Mine is the other way round. I got a HKS 2530 and a Greddy BOV plum back and has flutter at low revs and in med revs you get flutter then a little psshhh and when i give it stick i get alot of pshh and very very small flutter. I have an adaptor plate between the pipe and bov which i need to check to see if it's blocked or not. Sounds awsome but thinking of going back to stock just so it's one less thing the cops can pick on.
  • Replies 188
Yea, I know what you mean dude! It's one of the first things cops look for... And who's to say some cops won't b sitting in a shopping centre car park when you go to change gears...
All of a sudden you see, two red and blue flashing lights in your rear mirror and hear woop woop!!! :(
is it true that some people have been pulled over and asked to rev their car???
That's why I was trying to find a way of blocking it off making it look stock but also wanting some flutter when I give it a good bit of stick...!
Chestnut, the spring rate in your BOV is what is causing the flutter on throttle release on low pressure and has the wssssh on throttle release after giving it plenty. I would highly doubt that you would have the BOV blocked off.
I am running the standard BOV in the sedan, and it flutters in gearchanges under load/high boost.
Only mods that i think contribute to this effect are the trust metal intake pipe, the standard BOV return pipe (which has been slightly modified to accomodate the metal intake), and the blitz pod filter. So it's a very standard looking set up. No coke can / blocking plate bizzo
Take you BOV off and you might just find it been blocked by a coke or JD can :P
well seeing as its another SAU;SA members old car, do you know something I don't Krish? LOL
I haven't seen anything like that though, have taken the crossover pipe off a few times now to replace plugs etc.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
