  • Replies 65
If i were you i'd buy Vu's... Slotted are really a waste of time and money unless your either pushing big power or circuit racing.... 33 gtst's have exceptional brakes for everyday/hills and even light circuit work :D
If i were you i'd buy Vu's... Slotted are really a waste of time and money unless your either pushing big power or circuit racing.... 33 gtst's have exceptional brakes for everyday/hills and even light circuit work :)
gettin vu's on friday :)
just need to get brakes and hubs now :D:D:(
well this is soprisingly conveinient haha! im in need of some 5 stud hubs for the rear of a R33 too haha!
does anyone know if you have to use GTST calipers with the 5 stud hubs or will the GTS calipers still fit up no probs?
no you could keep your old calipers why
1) why
2) why
3) you would need to re drill your 4 stud rotors to suit 5 stud (not a hard task)
yeah go slotted,
1 the rotors will be brand new
2 slotted ftmfw!
get steve to get you qfm pads aswell, worked sweet in my 33, so they will be more than enough for your 33 :)
what are the qfm pads like are they good ive always used ebc red stuff.?
cool might hit you up in a few weeks steve i will give em a go ive been using ebc red stuff for a year now great pads only down fall is dont use cheap brake fluid or it will boil real quick
the red stuff dont squeal when upto temp and it has a beding in compound on it too are the qfm similar to red stuff
i have No idea how they compare to the red stuff as i said mine squeal possibly due to a wrong bed in process
lol Mitch its ok power will be better when i get the rest of the most to make the turbo's full potential
1) why
2) why
or pick up a set of R32, S14, 15 rotors as they are all 5x114.3 by 280mm the same as the GTS, not sure about the thickness though, but as Steve said they aren't that hard to redrill and it would probably work out cheaper (through growly :wink: :wink: ).
I also agree with steves first two points;
WHY and WHY.
Edited by D_Stirls
QFM are fine i have the K550's I'm not sure if i didn't bed them in properly but when up to temp they squeal a little
Same with mine... when they heat up they squeal ALOT.... its kind of annoying, not really the sound itself but more the fact everyone looks at ya thinking WTF lol
least your car doesnt sound like a go kart :)
on another topic , i just found out im not insured ! :)
who do you recommend me insuring my car with ?
its N/A (for now...) and i havent had a car accident ever
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
