Hi guys, I've got an S13 with an RB25 engine in it, and I'm remapping it myself.
I've got some mild knocking numbers close to the redline (it's got a power-fc pro, so ignition cut on revlimiter), and I'd like to know if there is any difference between the front and back knock sensor...
And for the record, what a/f ratio should I be aiming for at what load level ?
William
the knock sensor signal in the powerfc is presented as a single value, that is, you can't see both
the only way to log both would be to have a multimeter on both signal wires
you sure about that ?
Have you played with the raw logging data that you can save out of the datalogit software and then import it into excel?
It has 2 knock values. they are different values on my engine, the rear of the engine is nosier then the front on mine. which showed up on the stock power fc datalogit knock sensors & on my Gizzmo KMON.
Your such a help mate.. lol
Sorry. Start logging with datalogit and when you wish to see what you have run, save the log file or when you disconnect it will ask if you wish to save, open the log file with notepad press controll A. edit copy.
Open microsloth excel and paste into there. Drag down the sticky cells to the cell information and the first knock sensor is there, scroll across to see the second knock sensor.
I delete all the crap i dont need and have a excel file with all the usefull information i need.
one tip, Knock with a power fc.. = BBAAAA BUMMMMMMM totally useless information with anything more then 200 to 240rwkw and above.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
