hey ppl
just a question regarding engine oil
how much oil does a R34 gtt need?
im just changing oil and ive dumped the old stuff and it bareley looks like theres 2 and a half litres that ive dumped is this low? should of checked the dipstick b4 dumping but obviously too late to do that now
lol
thanks
jason
https://www.sau.com.au/forums/topic/241675-could-be-a-silly-question/
??? Im not sure if its the same but an rb26 is about 4.6 litres at minimum; most people put in 5 for extra protection around high speed bends.
2.5litres is waaaaay to low; did your oil light ever come on?
ha yeah thought it was a bit low nah no oil light
i was guessing about 4.5 litres
all good now thanks
Yea my r33 has perfect oil level at 4 litres. Did an oil change in a mates R34 and had to use the full 5 litres and it just hit the minimum line on the dip stick... wierd.
that is weird, i usually put 4.5 - 5 litres, seems to fill her up nicely ( R34)
Im sure your not that silly, but was this before you filled the filter?
Im almost 100% positive that the OEM manual says that they take 4.5 litres.
Thats what i always put in mine and it doesnt go above the F mark. Even 5L (that i put in for track, maybe a little over) it didnt show a great increase on the stick either.
Was after, filled with oil. Ran the car to fill up the filter. Then checked the level, and then added more oil and kept checking. Found it real strange.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
