hey guys i know this is in the wrong place etc etc but just need this answered quickly and haven't found any information on it. mods can lock/delete once its been answered.
radiator stuffed up on me 2 days ago and in need of one by tomorow or tuesday. i can get a r32 gtr radiator for my r32 gtst but just wanted to confirm if its compatible. wiring, fitment, mounts are all the same as 32 gtst radiator? is a gtr radiator thicker? if it is will clearance be o.k in a gtst? what coolant can i use? is tectaloy 90 plus alright?
also if anyone has one in westside or have one at all please pm me as the one i'm after is a bit of drive for me.
thanks guys.
o.k i'm kind of strapped for cash atm and not really in for a whole recondition of my radiator as i can get a couple of radiators for gtr for less than $100.
http://www.skylinesaustralia.com/forums/R3...amp;hl=radiator
theres damage on that top pipe where the hose goes on to...does that look like it will leak like a mofo even with the hose tightened up? also this one doesn't come with a shroud so will a gtst shroud fit on it?
there is no way that will hold, where its broken the hoses stops rite there
even if you did get it say plastic welded it wont be as strong and most likely break again
either have yours fixed or find one that doesnt have the broken hoses
cause itll be going from one headache to another
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
