Have just had my car tunned 98 GTR
list of mod
steel wheel turbos
HKS evc boost controller
Hard intake and cooler piping
cooling pro fmic 80mm
tomei fuel reg
std injectors
std afm
std fuel pump
manifolds
std dumps
3" fronts
3" exhaust straight threw atm
lightened flywheel 12lbs
pfc
cam gears
after tune got 260awkw with injectors at 96% duty and didnt want to push them any harder had fuel pressure bumped up to 70psi running 1.25bar have included dyno sheet.
is this a good tune? have read others dyno resaults and some getting 300awkw on std injectors why are mine maxed out?
https://www.sau.com.au/forums/topic/241868-gtr-dyno-tune-260kw125bar/
list of mod
steel wheel turbos
tomei fuel reg
std injectors
std afm
std fuel pump
manifolds
std dumps
3" fronts
pfc
cam gears
Try running less boost and more timing. And are you sure the tuner wasn't just winding in the fuel to compensate for a dying pump? Maybe a new pump might help to keep things in order. But without seeing the car, it's anyones guess really.
I did not read this before.. but I agree your fuel pump needs upgrading.
I would also replace injectors with new 550-700cc depends what you want to achive and headroom.
Replacing old parts for new is a good thing and a safe thing to do.
std fuel pump
Hey,
It should be easy to figure out whether the pump's not up to the task - get a graph of
fuel pressure on one of those runs (or have someone watch a gauge if it's in the engine bay),
if it falls off at maximum flow your pump needs help.
Regards,
Saliya
I also think dying fuel pump.
Silly to bump the rail pressure without checking the pump is ok first.
Very dangerous infact as in a few weeks the pump could be in even worse state then you'll really have more drama's
Seems a little low..
Stock turbos, injectors, no gears, just exhaust/dumps & power FC made me 250kw at 12 psi.
That’s actually a little high… 250rwkw is generally a result of 1bar.
fuel pump seemed fine i watched the gauge and held pressure strong but at 85psi its was bouncey on the gauge so that why we wound it back to 70 and when on a dyno run it woundnt drop back down or the neddle wounldnt go bouncey at all. but i have just bought a 044 im setting up a swell pot in the boot because i do hill climbs but really dont wanna drive 400km to get another tune on it already have already drop $1000 into tuning it.
when put this new fuel pump in will it stuff up all the a/f ratios?
Very much a potential yes.
If your running a higher than stock fuel pressure to counteract a dying pump
And then put the new pump in, you could find that its running even more pressure = bad.
Ha, yeah they need to learn how to scale their graphs a little better...
Did you run a flow test on it? No point having pressure if you got no flow.
Of course the a/f will be affected, if people are running 280 maxxing the injectors out, and if yours are on 96% then you technically should have almost 280kw worth of fuel going into it with a decent pump.
and theres no way you get 260AWkw running standard turbos and under a bar HAHA.
well he said "steel wheel turbos" not standard turbos. (or did you mean someone else?) certainly my 32 n1s give me about the same at 0.8 bar which is all we are allowed to run.
travis we make very similar power in our targa car at 0.8 bar using standard injectors, standard fuel pump, standard afms etc. we are also running over 90% duty cycle which is high enough for me considering how the car is used (no point pushing it to a dangerous level when fuel quality and temperature can vary so much). Not sure where these 280 or 300kw numbers are coming from standard injectors unless maybe they mean rwkw not 4wkw?
definately check the fuel pump is OK to be safe but we don't get any more than you do with new pump, clean and tested injectors and nismo adjustable fpr. easy to check since it sounds like you have a fuel pressure gauge - pressure should climb with boost right to the top of the rev range...if it drops off up high you have fuel pump or fuel pump wiring problems
yes i noticed it to that it only goes to 140kph, the tunner said something that it wasnt getting traction would this be the case and he said his rollers where warn? i will be putting a swell pot in and a 044 pump and i re-run the wiring aswell.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
