  • Replies 241
Posted Images
aaahahaha you should have seen me at last Final Battle. That was where I met Ian (XMetal Photography) but I was passed out in the car so he just left me a card :D
lol
okey dokey people... for your viewing pleasure, here are alsmot all* of the vehicles that will be in our display! :D
*Just waiting on one more (made 530kw last time it was dynod)
Anna - Msnismo - 340kw before the new turbo
Bakes - Stock(ish) 34 GTR
Stephen - Zilch - 270rwkw, bayside blue, hella nice to drive, lots of aftermarket parts (I want to steal)
Carl Ronning - 530rwkw V35 - may be an R35 if it is sold before the weekend
Marijan Angelski - 436rwkw last time it was dynod - upcoming HPI feature car
Charlie- NXTIME - I have no idea what he's done to this now, but it sounded tough as shit last time I saw it, and whenever he talks about it, I have no idea what he's saying, so it's something special :down: - R32 GTR
also, I have no pic of it :(
Received this via email yesterday:
Hi,
Thank you for you application to attend Auto Salon.
This email as your confirmation of your private/team's entry being received. Please note the following points below regarding your entry.
1. Photo's are required. If you have not submitted these before, please forward a maximum of 5 photo's per vehicle via email for reference purposes.
2. Please be aware that every entrant wether club or private MUST have flooring for car spaces purchased each is 5m x 3m. Questions relating to this can be directed the me in the Championship Department. (Must be Fire Retardant & have underlay if messy substance and must be removed by you at the end of the event)
3. Please be prepared to arrive at the show before 10:00pm on Move-In day. Lock down will occur and you may loose points, be disqualified or be replaced by a late entrant if you have not checked in by 10:00pm
4. Please remember that anyone entering the premises during the Friday Move-In MUST have closed toe shoes on or they will be refused entry and children under 14 are not allowed during Move-In.
5. For those competitors that entered via our online system, please go here http://www.autosalon.org/PDF/entry_form_08.pdf and complete the "Vehicle Spec Sheet" located on page 3 then send it back via fax or post.
6. No private competitor regardless of being in Pro or Expert Class is allowed to actively promote a business, regardless of what sponsorship deals they have. In order to promote a business either the competitor on behalf of the business or the business themselves, will have to reach a trade agreement with Auto Salon.
I will contact you the week of the show to confirm your nominated move-in time. If you have not received accreditation including your Move-In time two days before the show, please phone 02 9667 8306.
Please feel free to contact me if you require any further information.
Regards,
ALISA LAN
Championship Development Manager
So, do we have flooring etc organised??
for points 1 through 6... don't worry about it :)
It's all under control :)
The photos are for a new program they are running if you want your car to either be publicised, hired out etc... mostly for the major show cars
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
