note- looks like rust is on the water/oil pumps and the timing belt bearings, which will be replaced with tomei/n1 items...
is it too far gone?
and are they forgies?
engine kinda fell into my lap
digits on pistons are:RA9603X 0.50
RIB 0.10 SB
Edited by r33cruiser
Those part numbers are from an ACL Race Series forged piston. They are 20thou oversize. Being an RB26, they will actually be a ROSS Piston. If you look on the under side of them straight under the gudgeon pin, you will notice the ROSS brand has been CNC machined off them.
Engine also looks to be R33 GTR or could be N1, check for markings on the block as I can't read them properly on the side from your photos.
The rust will be ok, just have it cleaned properly. Make sure you have the piston to bore clearance checked when you disassemble it to make sure it will be a good engine when you are finished
u are f**king beautiful. i LOVE U!!!!!
the dude gave it to me as a rb25, are u 100% sure its a rb26 ??!?!!?
in that case, i will look out for an rb30 head :P
Sure looks like an RB25 block to me, no provision for rear turbo drain, different head gasket pattern. Not familiar enough with an RB30 to say if the block could be that. At .50 mm oversize and with rusty bores you should still be able to rebore it and be safe. The block needs a deck skim, too, to clean the head face surface up.
edited...see below
You are actually correct Chris. It is an RB25. I just looked up the part number on the ACL website. The part number of the piston is RB25DET but the block has the provision for the alloy sump with front diff so I'd say it's out of a GTS4. Sorry to get you xcited Cruiser :P
why put an RB30 head on it? they are SOHC. it will be a 2.5litre SOHC nugget.
to me it looks fairly fked. look at the rust on the timing belt gear and how corroded the oil pump is. I'm sure you can save it but it will take some work and money. in the end you probably wont save a lot over just rebuilding a better health RB25 to start with and you may end up spending just as much for an engine that has second hand gear in it. considering it's been outside with no sump on it for a fair while expect the crank to be rusted up nicely too. also check the pistons well, at least one has a nice little chip out of it that will make a hotspot. it's good for free, but just a shame it wasn't looked after. see if you can find out why it was pulled from a car and dissasembled in the first place. it's not normal for people to pull out a perfectly good motor for no reason.
in that case, i will look out for an rb30 head :)
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
PS that engine needs full strip, hot tank, deck and most likely all the internals will need hot tanking and so forth (new rings, prolly rusted). Its a fair clunker but if you got it cheap and the rings are cheap good find.
Edited by URAS
lol cheers dano... nfi why i said rb30 head :|.
yea consulted my mechanic.
of course its going to be stripped, chemically bathed, inspected, machined, honed etc etc. he 100% assures me it will be perfect. and he has his work to back that up
your are stupid for even thinking about NOT doing that!!
URAS mate, it was free, u believe that :(:D :D. so saves me about 2-3g's easy
thanks for all your help.
closer inspection of code: 08U, makes it a 25.
thanks again
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
