  • Replies 41
I have a R33 GTR with 230awkw, completely stock other than a cat back and an aftermarket ecu. I get about 420kms (I have not been tough enough to let it get on the E-line either). That is with "normal" driving with the occasional squirt.
Mike
PS: on BP Ultimate
Im on around 7 to 7.5 km's per litre of premium 98ron fuel used (metro area)
depending on fuel source, right foot, weather, traffic density and route travelled
generally 15L per 100kms
used to be better, around 12.5L per 100kms but my power output is ~90% more than when I first had the rb25det 3.25yrs ago.
i used to get f**k all...
when we had the kadina show i had to top up on the way back :P
i had a full tank when leaving in the morning, got there, dyno run, drove home, dropped my mate off at prospect
and had to top up coz the needle was under empty and the light had been on for ages,
so i got less than 300, prob coz FC was runnin pretty rich
Edited by craig R33
had 2 33s, lol, 1 i got around 350ks to a tank, and another i got bout 190ks to t tank, although the 190ks to a tank was a built 26/30 with 1700cc injectors, lol, spent abit of money on that puppie, <<<track only car it was, lol
yeah i get anywhere from 300-350-400kms per full tank
depends on the right foot
but my car is running pretty rich and running stock boost making around the 179rwkw mark
i get around 380-440ish depending on the conditions
Same.
Mines an S2 - I do stop/start alot though and was only getting around 320 when I first got the car. After a tune and major service its running much more efficiently and regularly get 380+
S2 33 4 door
cooler,turbo back 3 inch, pod and 12 pounds
210kw
using bp ultimate i average between 380 and 420km around town and thats including a bit of boosting....
my stock ecu makes the car idle wierd sometimes and likes to play funny buggers but overall im extremely happy with the performance and fuel consumption... espescially comapred to my old s3 rx7 with 48IDA weber'd 13 extend port, was getting 180km from 75 litre tank and that was tuned awesomely :laugh:
180km per tank..... damn... pocket painfull much?
bloody oath... i worked out i spent just over $11,500 just on fuel last year, thats what i paid for the skyline hahaha... god i miss the ol brap brap though :)
My R33 did between 400 and 480 km/50L depending on my driving style, 90% of the time it was around the 450km mark. It was making 190rwkw with a power fc. It may be a good idea to get your O2 sensor looked at.
  • 1 year later...
hey guys,i need a your help to find out what going on with my fuel economy...as you guys mentioned about your cars and mods and fuel economy my car not even near to that,recently i bought R33 GTS-T S1 Auto..
i changed and last week done service including..oil change,transmission service,plugs change,O2 senson change,brake pads change..total cost me $1000.. but no diffrence in fuel economy and power as well...my car is 1994...do you think i need to have turbo back exhasut....and fmic and pod filter to gain some more power...
i am new and dont know nothing about the skyline so please please go easy on me...guys...any help
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
