haha~
ARC? which one is more expensive? lol, if u think the NRG are good, then we can group buy it~, but where? from ebay? lol
and can u make sure if NRG has 2 bolts or 3 bolts on the mount?
cheers
I'm in Melb.
The other brand i know is ARC. I read the people in US really swears that the NRG are good. but i don't know.
I just don't justify to spend a Sturt bar for nearly AU$500 unless we as Whiteline to make one for us.
  • Replies 54
keep in mind that the NRG bars have issues with touching the bonnet. there is very little room between the engine cover and bonnet
i got mine form STILLEN (www.stillen.com) their bar is by far the best from what i have read and my own experiences. all you need is the 350z engine cover instead of the stock one and it still looks stock :D
i got mine form STILLEN (www.stillen.com) their bar is by far the best from what i have read and my own experiences. all you need is the 350z engine cover instead of the stock one and it still looks stock :P
thanks for the info mate~
and pw350gt what do you think?! :)
plenum spacers are rubbish...
all they do is increase the volume of the intake manifold and thus lean out the mixtures across the rev range. that can be done more safely with an ECU tune
i have yet to see 1 pre and post dyno graphy showing a plenum spacer doing anything.
its snake oil until proven otherwise.
dyno proof?
same car, same day, no ECU tuning?
i'm happy to be shown clear evidence
http://www.350zmotoring.com/forums/modific...rawford-v5.html
I've been reading about this a fair bit as well and from what I can see, the guys in the US seem to swear by it and the gains are pretty noticeable.
ok my thoughts..
first, i can't access the dyno graphs as i'm not a member ofthat forum and thus can't downlaod attachments. but assuming they show a gain my though don't really change.
the good points in that thread:
- same car
- same day
- same dyno
the bad points:
- test was not independent (ie it was done by the manufacturer) thus an element of bias
- there was no comparison made against a stock plenum, only against an aftermarket (crawford) plenum
- and finally, the biggest issue, what were the AFRs?
you see, i believe all it does is lean out the air:fuel mixtures by increasing the intake plenum volume of air. if you can show me the air:fuel ratios i think the spacer will just show that the car has leaned out and this accounts for the entire of the power gain
to make my point, a good test would be put on the plenum spacer and check power vs AFRs. then, take it off and put the stock plenum on and tune the ECU to run the same AFRs as it had with the spacer.
so unless the graphs so something like AFRs etc on it, that thread is no proof that the spacer works
  • 6 months later...
i think we should do a group buy to register our interest, then go approach whiteline...hopefully, they should be around $150 as all they are is a piece of strengthened aluminium, 2 bolts, 2 hinges...
anyone here knows a contact at whiteline that can help? i dun wanna be the leader on this buy and would leave it up to a more capable forumnite...
Maybe, at the same time, whiteline can also do all the other various struts and braces for the V35....come on guys, let's band together!!!
I can see what you are saying BUT if you believe the gain is because of a greater volume of air making its way into the cylinders, would you also agree that with the same AFR, more air and the corresponding amount of more fuel results in a bigger boom, that is more hp?
After all, that's what a super/turbo charger set up does but to a much greater degree.
90% thats what an ECU does anyway. Give the correct AFR. Why bother o2 sensors if that's not the case. I'm also very confused by this "without an ECU retune" stuff. I've read it in every counter argument. In order to make any modification 100% beneficial (even running the car on 98 instead of 100octane really should be considered) you need a retune. What should be said is, same car, same dyno, with a retuned ECU without the plenum spacer and a retuned ecu with the spacer. A retuned ECU either way is bias but a test without a retuned ECU isn't going to show any 'true' gains.
A final point on ECU's; If what you say about allowing more air into and through the engine is true and the ECU cant keep up, the same can really be said for any airfilter, intake or exhaust upgrades. I know that contradicts my above statement but 100% 'efficient' upgrade or not we know that, within reason, a freer flowing intake and exhaust will show power gains.
Dont mean to sound like an antagonist just trying to understand what you mean.
/hijack
I know this is an odd (and somewhat nuebie) question but what is so special that makes the bars so expensive? I mean I have a factory bar from an SiR civic here and its pretty simple. It'd probably take me an hour to copy it. Same can be said for the brace on my SW20.
Please correct me but my understanding is that its meant to be a fairly rigid device to prevent body/chassis roll. If this is that case how much technology needs to go into it? Serious question; I'd rather have a friend tig up a chrome one than spend a small fortune on the same thing with a sticker on it.
Regards
nick
Regards
nick
Well if you can get one made for me (a CHROME one) that will fit the v35 with a SKUNK2 plemun spacer i'll pay up to $300. If it's good enough
i can / will organise a group buy for the NRG one if people are interested...
Does fit to a sedan~? :)
i need one. but i have a plemun spaer. So if there is one out there that would fit i'll buy it quick smart
If so, here is the list~
1. V35_Paul
2. Japav
I did a fair bit of reading last night on the topic. I'll start with a mild steal one and if that works then I'll have my friend tig up a chrome one.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
