  • Replies 486
Posted Images
Lol im off thursday and friday! Ill be out and about both days though, Can pop past your work if thats easier for you? Or you can pop past lukes either night and pick it up from there.
yeah probly easier for you guys aswell, thursday might be better since im probly meeting few people at vilis friday night at this stage..
also, few people that submitted their photos but havent mentioned buying one, want to know if you guys still keen, as i may need to order more
Kye
Cronic
Cara
Dan
Ryan
I wont have them until thursday.. and I cant really post up the proof of them either..
I guess just wait until thursday/friday and see what people think of theirs and go from there.
I really do hope people like them, as myself and the designer put a bit of time into them. Havent seen the final printed ones yet, but the proof looked pretty good to me.
They are A4 from memory, spiral bound at the top..
yay my photo in the middle :P
as if your thinking if i like it i'll buy it. Its a calendar full of cars you love.....skylines. Whats the hesitation. It is very professional looking. People wont be disappointed.
me likey, well done guys :P
EDIT: I know this is SAU but I'd love to do a bike calendar one day..........only problem is that Roo has about 10 bikes lol, and there won't be any room for me.........not to mention that we would only sell 2 calendars on this forum :)
Thanks Luke :P
Im just questioning myself now lol making sure I told her all the right things, like gloss print etc. Sure they are fine lol, im just a worrier!
Now, ive been able to cut and paste a snip from the proof, just as a teaser.. of the bottom of the Febuary page.. if it uploads properly.
Thanks Luke :P
Hah sick! go pic number 3 *dances jig* yeh behbeh
-D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
