Hey guys,
Im on the verge of having my RB26 rebuilt, so after calling numerous workshops (local and interstate) and after being given lots of different quotes i'm still undecided as to which workshop to use.
I was quite happy with the quote I was given by Adelaide Engine Developments, but haven't heard much about them prior to finding them in the yellow pages.
Basically im just wondering has anyone here had work done by them?
Any input would be muchly appreciated.
https://www.sau.com.au/forums/topic/242797-rb26-rebuild-advice/
  • Replies 40
Posted Images
I've recently spoken with Lewis engines and quite happy with their knowledge and development with the RB.
Fairly reasonably priced also.
http://www.lewisengines.com.au/
- http://www.lewisengines.com.au/category9_1.htm
Unsure why the rb26 rebuild is worth so much more than the rb25/30 rebuild.
As bodgy as it may appear I had my 30 bottom end built up by City Dismantlers.
They checked the motor out and then gave a solid quite. Didn't go over by $1. Less than 3 weeks later the motor was completed, strapped to a pallet wrapped up nicely.
All up back then inc. all the usual line bore (crank), forged pistons, rod resize, block & rod crack test, forged pistons, grub screw & king bearings cost me 3.9k to also fit the head and drill/tap the upper tensioner position.
Motors been good, always made good power and has done 100,000km's so far. :D
The same things done to the motor from Miltons they wanted 6.5k :S
Main reason I went with City's is the bloke who was in charge back then (Andrew) was able to answer any question I threw at him without hesitation. He had a history in speedway since a young kid and built many a few tough vlt's back in the day so he knew all the little tricks to perform with them.
They had what looked like new machinery, workshop was clean and organised. Some of the places I checked out I wouldn't be suprised if they lost bits. :S
Either way fixed price with no umm's or arr's, clean workshop, organised and the bloke was able to answer questions others were not able to won me over. ;)
Thats exactly why i'm leaning towards Adelaide Engine Developments, i've only had a chat with them over the phone.
But the guy I spoke to knew exactly what the go was, apparently they've done quite a few RB26 in the past, and the quote was... a fraction of some others I have received. :D
I'll be checking out their facilities next week
Edited by Tommmo
John moyle on main nth rd blair athol, is who built mine.
and remember the guy you talk to on the phone is normally just a salesman.
you need to talk one on one with the engine builder himself.
Dave at john moyle has been building, and dynoing speedway engines for nearly 40 yrs.
awesome price, awesome work, and a engine dyno if you want to run it in beforwe you install it.
highly recomended
places like bdt dont have a machine shop, so your paying for a middle man.
i dont see the point.
ill build ya stinker
i had chris miltons
do all the machine work on my 30det and i did all the assembaly etc .
made over 364rwkw on 18psi cost me less than $3500 to do the bottem end !
in the process of building another 30det to back up the fact i make killa motors
AED are decent, build HEAPS of big hp v8 motors, and jobbie works out of there (head porter). They would have a solid base to work from building a RB26. Could even tune and run in on the engine dyno if you desired. I would recommend also, tony knight engines and john keen for engine assembly. I know a guy building a LS1 stroker now, and is trying out lewis engines machining now, as we are getting sick of the pricing from rhemacs.
Cheers
troy you may be very well qualified to do engine assembly but it's amazing how many others think they can, and all they do is push brgs in, add a dob of oil, drop the crank in and torque to specs without using inside & outside mic's to check clearances, without checking endfloat, without checking for brg crush and even chipping the edges off scraper & segmental oil rings while pushing them into the bores. Just because the crank's been ground doesn't mean you don't still check everything.......9 times out of 10 main tunnels don't need line boring unless a brg has turned or been hammered.........that's why we do all the above checks.
Hence why it's a good idea to get the engine reconditioner to also assemble unless your a qualified mechanic or engine reconditioner IMO, so +1 dangerman4
thanks for the feedback guys, can someone pm contact details for John moyle.
Cant hurt to get another quote :(
John Moyle Motor Engineering
1a Collins St, Enfield, SA 5085
p: (08) 8269 3214 f: (08) 8344 1202
i supplied all the parts and they did all the machining and assembly of the short motor,
i suggest you do the same, as you know what parts you want and they know how to fit them.
ie rods , pistons, crank collar etc.
Once again thanks for the feedback, but i've decided to go with Adelaide Engine Developments. The guys there were very easy going, quick to answer all my questions and brought up issues I hadn't previously considered. The wokshop (be it small) is also quite well setup.
Engines being pulled out and tuesday! Looking forward to the whole build, hopefully there's not too many hickups!
thommo was the blokes name from adelaide engine developments name chris smith???? i beleive him and his mate run that business i work with chris up here and hes apparently good hes going to do a bit of my new motor im getting.
cheers... michael
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
